Sultan of Sawzall
I've used setups like this before on Corvair engines (IECO made them), both on the 2 carb and 4 carb engines. The only problem I ever had was getting sufficient carb heat in the winter. Sure was alot easier than rebuilding/synching 4 Rochesters!
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
You guys forget that a holley has a CHOKE. Chokes are needed on daily driven cars for sure.
Senior Advisor
what do you guys think of two weber 2 bbl's on that set up. should fix the float problem and look kinda cool?
08 Cayenne Turbo |
go drive that thing at night or during a cool day- you can refrigerate anything attached to the intake below the carb= it ices up
same issue with the corvair single 4 bbl conversion- left us sitting by the side of the road till the tubes warmed up bad idea
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
... or how about a Rochester TBI injection system off of a Chevy Luv pick-up truck! No wait, with a little bit of work you could put on a Solex updraft carb from a Maserati race car, or better yet how about a set of 6 Stromburg side-drafts from a Jag? SU/Hitachi's off of a 240Z?
And then there are those really cool floatless carbs from Solex. Oh yeah -- Porsche tried those, and they didn't work as well as the Webers or Zeniths.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Why do you think chokes are needed "for sure" on daily drivers? I have PMOs--no chokes--on a car I use all year round except when it snows, and the correct accelerator-pump use makes starts reasonably easy, first of the day. (And thereafter, starting is absolutely normal.) In fact my daughter is better at starting it than I am; she can usually catch it on the first attempt.
I'm not saying it's anything like as easy as a modern FI car, but I wouldn't discourage somebody from trying to drive a chokeless car. It's an urban myth that they require chokes, just like it's an urban myth that carbs require constant tuning.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Southern Class & Sass
What the heck do you think Trans-Am cars ran in the '60s? What do you think NASCAR runs today?
Dixie Bradenton, FL 2013 Camaro ZL1 |
Crotchety Old Bastard
I used to have a '73 Widebody hooliganmobile with 40mm Weber and Supertraps. That was the quickest revving coolest sounding car I ever owned. On a 20* day it would fire up and sound like an Indy car as I pumped the trottle as fast as I could to keep it running until it warmed up.
And now for something completely different ...
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Senior Advisor
is that a 2bbl holey?
08 Cayenne Turbo |
Senior Advisor
hear is a holley for NASCAR with +- 3g capability of supplying fuel at any angle
![]() 850 CFM might be a little big but for $1200 bucks, it's yours!!!!!!!!!
08 Cayenne Turbo |
Almost Banned Once
The idea was if it got stuck open the extra fuel would wash away the oil from the cylinder walls. The theory was this lead to reduced engine life but that was a subject of much debate for a long time... Thinking back it was never really hard to get the car started. Two pumps of the gas peddle and then turn the key. As soon as it fired you then press part throttle to keep it idling. You had to idle it that way for about 3 minutes and then you were good to go.
I'd pay money to have a carb. setup like that. Maybe Holly will make one for us. ![]() Improvements are welcome, but sometimes re-inventing the wheel isn't necessary. Sherwood |
Senior Advisor
your talking PMO's! full circle
08 Cayenne Turbo |
Diss Member
BTW - That carb won't work 3 Gs in any direction. It can be made to work well at 3 Gs in one direction: left or right. Under hard braking it won't work well on race cars but they don't care. They don't care about mixture problems under braking as that only causes burbles and backfires. Besides every other car on the track has the same carburetor mandated by the rules so who cares? If NASCAR allowed any type of injection how many cars do you think would have carbs? I have actually built Holly racing carburetors. I still have some in the garage. (The 390cfm setup for the 3.5 liter Olds would probably work pretty good for the craigslist manifold.) Setting them up for road racing was work. Getting them to work on a road course with race tires was irritating. Here are a few tricks to pull out of the bag... - If it has side feed floatbowls (like the craigslist ad) replace them with center hung floats. (as pictured above) - Put in the plastic internal vent extensions to reduce fuel sloshing out the vents. (Most of the performance Hollys with center feed floats have them from the factory since the early 80s) - If the engine is flooding under braking because of fuel sloshing out of the secondary vent you can connect the 2 float vents with a loop of rubber tube with some small slits at the very top. That will let the fuel slosh into the other float bowl. - Soldering extension tubes into the jets is a given. For a circle track application the tubes can actually be angled towards the right side of the float chamber. - In extreme cases try movable jet pickups made with model airplane fuel hose and drilled out model airplane "clunker pickups". - Replace the brass floats with foam floats that can be trimmed to deal with the specifics of the fuel control problem. I could get the craiglist thing to work fairly good with some work and parts that I have on the shelf in the garage but I don't feel a need to punish myself. Basically the real world solution to the problems involved is to get a copy of Stock Car Magazine and call a few carb builders from the ads in the back to get a carb that has seriously been gone through. Once you have that ($$$) starting point you can then start tuning it to the engine. . . . Or you can go with a bolt on solution that is known to work. PMOs, CSI, MFI, or my favorite hot rod solution: Megasquirt.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Diss Member
It really helped out later when I learned there was more to driving then aiming the car...
muck-raker
Way back in the day, Holley made a 2bbl carb for VW called the "Bug Spray". Actually a very decent carb and juiced up my Bugs and Buses very nicely.
I realize that I'm comparing apples and oranges here...but it seems the general consensus on this thread is that the 4bbl has many disadvantages for an air-cooled flat six. Maybe there is a more suitable 2bbl out there? Maybe someone has experimented with one and can share their experience?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Free minder
Maybe a modification of the fan shroud to cover the intake pipes would allow such a setup to work...
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
My Camaro buddy sent me this regarding the Holley 4-barrel carbs:
"I installed a Barry Grant Mighty Demon to replace my Holley Double Pumper. More adjustments such as replacable idle air bleeds, idle feed restrictors, high speed air bleeds, and annular fuel boosters instead of dog leg boosters in the holley. All this means is you can fine tune the Demon to a higher level for much less money than a Holley. The demon annular booster fuel dispersion at low to midrange rpm is awsome. Much better low end response than the holley. The Demon copied all of the Holley's strong points and then made it better for a lot less money." FWIW. Sherwood |
AutoBahned
