After you put your 915 together you will probably get some R&P noise, hopefully it will last long enough to get you on your way to the conversion.
Keep the Shiny Side UP! Pete Z. |
Almost Banned Once
Just one last question. Since I'm taking it apart anyway, would it be worth flipping the synch bands in my gearbox?
I know you said you never recommend this but I figured in my case it couldn't make things any worse. And it may even shift a bit better until I swap out the box. ![]() |
Almost Banned Once
Hi all... Just thought this would be of interest. These are the differential bolts as removed from my final drive.
Notice that 5 out of 12 have broken in the same way. The threads of the 3 heads with the locking tabs attached were still in their threads in the crown gear. All three came out by hand. No tools!... The remaining un broken bolts were all just finger tight. Looking at these bolts I agree with Peter Zimmermans original reply that they were put in using an impact wrench. If you think about it all of the heads were broken off. That would take about more then 200ftps to do by hand... Amazingly the thing held together and was quiet... After this I think I'm going to start going to church again ![]() ![]() Last edited by sc_rufctr; 03-25-2009 at 12:12 AM.. |
Thread Tools | |
Rate This Thread | |
