ISpeed2day's Avatar
h4 upgrade problems
so I did the h4 upgrade
I installed 40 amp relays on the white and yellow wires coming from the fuse panel to the headlights.
40 amp relays
(post 30) I ran new hots into a fuse block used 20 amp fuses
(post 85) put good grounds on all relays
(post 86) line from original fuse panel
(post 87) line to light.
Now I am getting a very high pitch squeel from one of the relays and my high beams dont flash or come on.
I am lost.
Old 03-16-2009, 07:31 AM
UnRegistered User
billybek's Avatar
Sounds like you have something mixed up...
Pull your relays. Identify the contacts and coils with a meter and try it again..
If you can test your relays while they are out, it will probably help you understand what they are doing.
At least a bump to the front....
Bill K.
Old 03-16-2009, 04:35 PM
HarryD's Avatar
The contact numbers are right. Did you mirror them by some chance?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-16-2009, 04:38 PM
ISpeed2day's Avatar
Relays were all wired fine.
Problem was in the wiring between the switch and the dimmer relay.
Thanks everyone.
Old 03-16-2009, 07:55 PM
