JMAN718's Avatar
Change spark plugs today, but sounds flat.
I post this problem a month ago, my engine sounds and feels like its running on 5cyl. I just change out the plugs today, also check out plug wire at night to see possible light show, no show! I change the cap and rotor as well a month ago. I don't get it! Any ideals Guys? I need HELP!!
Thanks Jman718
Old 03-17-2009, 06:44 PM
Make Bruins Great Again
Por_sha911's Avatar
You may not have one of the spark plug wires on all the way. They need to connect to the plug with a distinct sound. Pull each wire and replace them and listen for the snap.
p.s. Nice color car!
Joe
Old 03-17-2009, 07:15 PM
JMAN718's Avatar
change plugs today...
Thanks Joe,
I made sure that they click in on every plug wire, because it was making the same sound and feeling before the change out. It just sounds and feels like it not running on all cyl. Could it be a valve adjustment needed? Help!
Jman718...
Old 03-17-2009, 07:51 PM
Por_sha911's Avatar
It could be an assortment of things not limited to:
Clogged fuel injectors, clogged fuel filter, valve adjustment. How many miles since the valves were adjusted?
Joe
Old 03-17-2009, 07:59 PM
madmmac's Avatar
What plugs did you use....make and model#
Did you get the wires on the distributor in the correct firing order?
Take a pic of the engine bay area and post it.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
the the is offline
switched wires, bad connection, broken connector.
since they are brand new plugs, if you pull them, you'll easily see which one(s) have not been firing.
Old 03-17-2009, 08:12 PM
JMAN718's Avatar
change spark plugs today.
I had a new fuel pump and fuel filter install last year Sept 08. I don't drive this car as a daily driver. When I bought this car in 2005 it had 84k mi on it. It has 121k now. The last minor service done on it was Sept 08, and they told me that the valves sound fine. They would adjust them on my next major service? I mark all the plugs wire so there would not be a problem. I use NGK BPR6ES 7131. Gap @ .028 ... I Don't get it? Thanks Jman718
Old 03-17-2009, 09:23 PM
Make sure the plugs are snug in. Also, h2o in gas will cause sluggishness. Good luck. This $hit can drive one crazy...
87 blk coupe
Old 03-18-2009, 12:57 PM
emac's Avatar
Jman
If the car was in fact running good before you changed the plugs then it has to be either a bad (new) plug or you could have broke a wire when you were changing. If you took the wires off one at a time and change the plugs that way you could not have crossed a wire.
You can pull the wires off the dizzy one at a time and when you do you will notice a great diffenence in how the car runs. When you pull the bad wire/plug you found your problem.
PS DONOT GET KNOCKED ON YOUR ASS WHEN YOU ATTEMPT THIS. INSULATED GLOVES
Ernie 81 SC
Old 03-18-2009, 01:04 PM
I suspect a bad plug wire. Test resistance with a multimeter set to "ohms". The connectors unscrew from the wire so you can replace just the connector if it's bad rather then the whole wire set. Sometimes the resistors internal to the connector can fail also. I had a bad wire that corroded internally at the dist. cap connector. Took it apart and cleaned it then worked ok.
Old 03-18-2009, 02:45 PM
Por_sha911's Avatar
I don't think this is a problem that surfaced after the plug change
Originally Posted by JMAN718 View Post
...it was making the same sound and feeling before the change out.
Joe
Old 03-18-2009, 07:13 PM
JMAN718's Avatar
Thanks Guys for all of your ideals.
I will check on the plug wires tommorrow. To be continued!!
Jman718
Old 03-18-2009, 10:01 PM
DanielDudley's Avatar
Buy new plug wires. Buy a new cap. Buy a new rotor. Get the valves adjusted. Get a compression check.
A hole in a valve will kill the compression in one cylinder, and eventually lead to a dropped valve, which will lead to a $10,000 BILL, LOL
You get the valves adjusted every 15,000 miles, so you are HOW far behind schedule ?
Old 03-19-2009, 08:10 AM
dshepp806's Avatar
Do measure the wire resistance (amen).
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-19-2009, 03:53 PM
