Newbie - specs on lowering
Dreaming of a Porsche for 30 years owning one for 3 months - 82SC. Just wondering about specs on lowering. My car seems pretty low and has 50 series tires. Does anyone have measurements I can compare to my car?
Thanks KW
From that angle the height and the rake looks right. The front has room for a spoiler. I believe the measurements you are shooting for is 24.5" rear and 25.5" front. This measurement is from the earths surface to the top of the wheel opening.
Looks like you have 16X7 wheels with 225/50 tires. Take measurements of all four heights and see what you come up with. OBTW..great car!
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Welcome Newbie,
You have a nice looking car. I have 83sc and it had been euro spec lowered before I bought it. I have been told by a service tech that you really don't want to go lower than that. Also, I believe it would have a real harsh ride too. Have fun driving your P-car, there is nothing like them.. Jman718
durn for'ner
Welcome!
Lovely color! Where are you located?
Markus Resident Fluffer Carrera '85 |
a.k.a. G-man
Welcome.
nice looking car, ride looks ok, maybe a bit lower in the front.
Сидеть, ложь, Переворачиваться |
How much petrol in the tank when the pic was taken?
Looks about right. Interesting color.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
muck-raker
Sharp ride.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I've done a lot of searching over the past week or so on this subject. Euro ride height is 25" at rear and 25.5 at front as best I can determine. Your car looks a touch low at the rear (maybe 0.5"), which probably can be adjusted using the spring plate adjuxtment bolts.
Seems that at the very leats there should be a half in difference front to rear, front being higher. Measure the height from ground through wheel centre to guard. Conversley there should be 108mm (+/- 5mm) between torsion bar centre and wheel centre at front and 12mm (+/- 5mm) at rear. I just rebuilt my rear suspension. My first shot saw 25.25" at rear (although this still may settle slightly) - close enough for me !Will post pisc on the weekend.
Sheldon '92 964 Carrera 2 (Manual) '07 BMW 335i '76 911 Carrera 3.0 (Gone, but not forgotten) "Give me ambiguity or give me something else!" |
Designer King
The Euro height of 25R and 25.5F are based on tires that are 25" diameter. I like to follow the same principle, regardless of tire size. My tires are 24" diameter (205/50/16) so my rear ht is 24" and the front 24.75". I like a little less rake. If you have 225/50/16, that would give you 24 7/8"R, w/ the fronts 1/2 to 3/4 higher. Based solely on that pic, your ride height looks good to me.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 03-19-2009 at 05:40 AM.. |
Is the color on the car "Velvet Red Metallic" or "Arena Red Metallic" ?? Looks great!
Andy Last edited by AndyK!; 03-19-2009 at 09:37 AM.. Reason: clarification |
Thanks for all the great info. Just got a foot of snow here in Montana so I needed a good garage project. Color of the car is Red Wine Metalic.
KW |
muck-raker
"Project", huh?
Wish I had a "project" like that.
