daily driven 911
missing CIS adjustment screw!!!
so i was going to tinker with my fuel mixture on the 82. I get the mm long Allen wrench and let her warm up. i found the hole, put the wrench in and was surprised at how far in it went ( about an inch)!!! then the idle dipped, and almost stalled.
am i correct in thinking that it is missing..
my mechanic was in there just about a week or 2 ago. she ran GREAT that first day i picked her up and then went back to running like crap. is it possible this has loosened it self up and fAllen out. or he didn't put it in there......
Old 03-21-2009, 02:28 PM
Poor-sche Lover's Avatar
It IS a long way down in there, longer than I thought it would be. You're using a 3mm wrench, right? I think the wrench needs to be five or so inches long. I always had to fiddle with it until I could get the wrench in the head of the screw. Good luck.
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 03-21-2009, 03:02 PM
Zeke's Avatar
I've not done this, but I loaned 3mm wrench to someone at the track. It was not the long model and they were successful. Going by that, I'd say it's somewhere less than 5".
Old 03-21-2009, 03:08 PM
daily driven 911
ok....its in there. seeing the screw threads threw me off. I can feel it in there.
Old 03-21-2009, 03:17 PM
daily driven 911
why would my idle dip when i push down real light on the Allen wrench???
Old 03-21-2009, 08:21 PM
Any movement will cause it to dip, it is very sensitive and you should not push down on it, If you decide to adjust it with the engine running then you will see when you turn it just a little it may cause the car to stall. That is why it is very important to remember exactly where you started. If your car is running now then you can use Souk's method off finding the middle point between rich stall and lean stall.
But, why are you adjusting the mixture?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-21-2009, 09:42 PM
Senior Advisor
James Brown's Avatar
oh well, here we go again!!! look and read all the old posts on cis adjustment or under cis fuel/air mixture adjustment.
again, this is not something you should adjust like a holley! read EVERYTHING you can and get some special tools BEFORE you start turning screws.
08 Cayenne Turbo
Old 03-22-2009, 12:00 AM
T77911S's Avatar
i use the long allen that came in the sears allen set. i works perfect.
you are pushing down on the plate thus changing the mixture.
remember to remove the allen before you rev it up, dont leave it in there.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-23-2009, 04:33 AM
Nothing is going to change if you dont unplug the ox sensor and replug it up when the changes are made
Bruce
Old 03-23-2009, 06:13 AM
