Senior Member
Superman's Avatar
Ride Height Decision
I need to make a final decision on ride height. I need to hear from people who actually know. Steve W., Grady C. and Bill V. come to mind, along with others. I am not particularly afraid of bump-steer, but am told I might run out of suspension travel if I go too low.
Car is a '78 SC that I think will tip the scales at about 2400 lbs. 22/29 torsion bars. Late Carrera sways. Fresh Bilstein heavy-duties (cannot afford the right shocks right now). Steering rack spacers. Elephant front bushings, Neatrix rear.
Everything has been assembled and ride height has been temporarily set at 24.0 rear and 24.5 front. Do I settle on this ride height.......or must I increase height another half-inch? Or inch? Or quarter-inch?
Mocha 1978 911SC. "Coco"
Old 08-05-2009, 09:47 AM
(the shotguns)
berettafan's Avatar
have 22/28 on my '70 and i would suggest you'd have a hard time running out of suspension travel with such a setup.
Old 08-05-2009, 09:52 AM
Senior Member
Superman's Avatar
I'm not afraid. But I've been told by a reliable expert that 24/24.5 may be too low. Because of lack of suspension travel.
Old 08-05-2009, 10:09 AM
(the shotguns)
berettafan's Avatar
i would think you'd need to know t-bar info to make that statement. UNLESS the issue is roll center which i understand to be a geometry issue.
Old 08-05-2009, 10:22 AM
Senior Member
Superman's Avatar
I mentioned torsion bars. 22/29. This expert knows what I have. And he seems to think 24" is too low.
Old 08-05-2009, 10:40 AM
175K911's Avatar
FWIW, I'm about the same ride height as you but I've got 23/33 torsions, custom valved Bilsteins with front rods shortened 19mm, weigh just under 2500 lbs. 99% a track car. I can drive it on the street, but this ride height is purely track based, and I'm a whole lot stiffer than you. Before I had the front Bilsteins revalved and rods shortened, I could bounce the car off the internal bump stops on hard bumps in the road, and that's with a 23mm front bar.
I can't imagine you aren't bottoming the shocks up front on a regular basis. If it was me, I'd go up half to three quarters of an inch. But that's just me.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 08-05-2009, 11:08 AM
Formerly bb80sc
Vipergrün's Avatar
I assume you have cut down the rubber bump stops in the shocks and removed the 10mm spacer at the top of the struts?
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 08-05-2009, 11:17 AM
David's Avatar
I'd go up a 1/2"
Old 08-05-2009, 11:57 AM
Designer King
Paulporsche's Avatar
What size wheels and tires do you have?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-05-2009, 12:41 PM
sbrown.nw's Avatar
Here is what Byron at Tru-line in Bellevue, WA (known local suspension setup expert) set the ride height at after a 4 wheel align, height and corner balance (pre-loaded with driver's weight in car)
front: 24 5/8
rear: 24 1/4
I am running the following tire and rim setup:
17x7.5 - 215/45R17 - 34lbs tire pressure
17x9 - 245/40R17 - 40lbs tire pressure
Car is about 2600lbs with 2/3 tank (no driver). Non-HD shocks and factory tbars.
Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now
- 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs
Old 08-05-2009, 01:00 PM
AutoBahned
RWebb's Avatar
set it a tad high then see how many gas stn. driveways & parking barriers you hit
re-evaluate from there...
Old 08-05-2009, 01:23 PM
blk911's Avatar
Superman,
Another thing to consider is that you lose castor when lowering. I think below about 24.5" in front, you will notice the steering a bit more twitchy. Turn it is great, but very sensitive to steering input. Driving straight line makes you pay more attention or you are changing directions. Not always confidence inspiring.
I feel the need, the need for speed.
Old 08-05-2009, 03:54 PM
Originally Posted by blk911 View Post
Superman,
Castor would not change but the additional negative camber would make it twitchy and steer heavy.
Old 08-05-2009, 04:03 PM
Bill Verburg's Avatar
the ride height is fine w/ the bigger t-bars(as long as the tires are clear), bump steer is the concern, you may(likely do) need a tie rod end bumpsteer kit as sold by Elephant & Smart Racing
for street /track 0 pressed toe is good for A/X they run some toe out but this makes the car darty, max castor and camber(unless you use camber plates in which case ~-1.5 - 2* is usually good, rear 0 toe and -1.5 -2* camber is good
Bill Verburg
Old 08-06-2009, 04:16 AM
Senior Member
Superman's Avatar
I raised the car last night from 24.0 (rear) to 24.5. Now it sounds like I could lower it a tad bit. Perhaps 24.25.
But I have more questions:
What is "pressed" toe?
Camber plates? I may go head and run a tad bit of toe-in in the front, to help control some of that dartyness problem. This will be mostly a street car.
What effect does rear toe have on handling. I'd guess that rear toe out would make the car oversteer more. But I don't know. I have a suspicion that our rear suspensions toe out a bit when the suspension is compressed. Is that a correct guess?
Old 08-06-2009, 06:30 AM
AutoBahned
RWebb's Avatar
means w/ wt. on it
Old 08-06-2009, 07:36 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Our stock '86,
25 1/4 Rear
25 7/8 Front
Car looks great, no issues.
Work performed by Johnsons Alignment
in Torrance, CA
Old 08-06-2009, 08:29 AM
pressed toe - an adjustable rod is used to press the leading edge of the tires apart, simulating what happens on the road. the amount of force is speced @ 15kp(~33lbs)
toe out promotes dartiness, toe in quashs it. 0 pressed is good though for a/x you might want some toe out to promote dartyness
rear toe works just like front most street cars will have a small amount of toe in, toe out promotes dartiness in back, toe in quashes it. 0 is good but again for a/x you may want a small amount of dartiness. The Weissach effect used from 928 &964 up selectively promotes toe out on one side and toe in on the other, steering the rear thru a corner.
yes, toe out in back promotes oversteer and toe does change w/ suspension excursion. But w/ a stiff suppension change is limited, all you can do is set the static #s and live w/ the dynamic ones
Bill Verburg
Old 08-06-2009, 12:24 PM
