Removed this part: CAN'T remember where it goes back!
Dudes. Dudettes.
I removed this part for powdercoating along with a whole mess of other things. Time has come to put it back and I can't remember where it goes, and I don't see it in any of my pictures. Any ideas? Oil line bracket, or something? Please help! Thanks!SmileWavy http://forums.pelicanparts.com/uploa...1238111247.jpg http://forums.pelicanparts.com/uploa...1238111258.jpg |
yOUR WALLET!
pAUL |
D'oh.
probably someone else's part got tossed in with yours.
i agree. never seen one of those before.
Don't mean to beat a dead horse here, but this reminds me of those PCA meetings where someone brings in a "mystery" part and we have to guess what it's for.
One time, it was just something someone picked-up in the parking lot. Too funny. Of course, so were the responses. |
That's what holds the muffler bearings in place on a 74 RSR and is made of unobtanium. Priceless piece you have there. Wanna sell it?
LOL. I really have no clue. |
This is exactly what I was saying!! ROFLMAO |
..maybe part of an aftermarket battery conversion bracket?
it looks aftermarket whatever it is. |
I grew up with formica counter tops with that same gold fleck pattern....
Maybe it's my Johnson Rod spacer. Or the bracket for my turbonator.
Attempt to put the car back together and if you don't find a use for it.. you don't need it. :)
It's a piston return spring clamp. It goes between the muffler bearing and the left handed smoke screen.
If your car is burning gas on the right side, you need to mount it on the right. If your car is burning gas on the left side, you need to mount it on the left. Or vice versa. It is a pretty simple application, depending on what side of your car is burning the most gas. Just remove the door handle and spot weld the return spring onto that side. It's magnetic and the springs will sense that. Don't weld it too close to the springs. Not only are they sensitive, but a piston return spring magnet welded too close to the piston will look stupid. You don't want that. |
Come on guy's, that is a guzinta valve bracket, everyone knows that.
OMG! Now, I remember...better send that back to MM for the rebuild.
That's the fetzer valve bracket. Prep that with some 3-in-1 oil and gauze pads.... it's all ball bearings nowadays...
I like it when someone tosses in an xtra part, Kind of like my Brother putting in one xtra thru bolt O-ring during an engine build!!
Any chance at this point you might ask the powder painter if one his customers is missing a part? He probably wouldn't admit to it anyway...
| All times are GMT -8. The time now is 08:38 PM. |
