Almost Banned Once
Damn...
There is so much info here I just have to do my gauges this winter. ![]() My to do list is getting longer and longer the more time I spend here.lol
- Peter |
Maybe this might help: http://www.villagehatshop.com/miners_helmet_light.html
Go Speedracer, go!
Here's my quick 5 minute install on the spare clock:
Here is the guts of the clock with the tape installed. The wire is going out of the original light bulb socket hole. You can see my botched attempt at adding additional LED bulbs on my first experiment. ![]() Here it is with the face installed. You can see there is a thin strip of light all the way around the face of the clock: ![]() Here it is with the inner bezel in place. Just enough so that some of the strip is visible. This is why I think the wire would actually work better here: ![]() Here is the whole package with the inverter hooked up: ![]() Hope that helps answer some of the questions I got.
1981 SC ROW Coupe |
Member 911 Anonymous
Hey Speed,
The wire is 2.3 MM and liken to a normal electical wire that is semi rigid so it can be formed. I quickly measured the opened clock and the space between the black face and the rim appears to be the same size so one can feed it thru the original hole for the bulb then out the front and shape the circle and rtv it down. This way we don't have drill or cut the guages. (like your 3rd pic) I think for crimping, you can use one of those narrow hand rollers like those used formica workers. We can use RTV and spot glue it to the rim of the guages.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-02-2009 at 01:05 PM.. |
Go Speedracer, go!
1981 SC ROW Coupe |
An idea on making our own 5 way splitters:
Place male connectors to ends of the El-Wires that will be coming out of the ports where the existing light bulbs go in. Solder 5 plain wires to the Inverter leads and place Female Connectors on the other end. This would allow for servicing of the guages one at a time with the quick disconnect connectors. Does anyone know if 2K or 3K Hertz is better? I assume 3K would be better but not sure.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Almost Banned Once
Someone should put together a complete "kit" designed for the 911...
People will pay a little more for a kit that works and is simple to install. It would include "5 light" rings, wiring, inverters, some simple instructions and an appropriate glue... You'd sell heaps...
- Peter |
. Unforutnaely I deleted the link because the shipping to the states was horrendous.
Here is the 5-way EZ connector I was talking about. Just left a message for VibeLight.com to let me know how we can order the 2.3MM EL-Wire, their site is broken
Top left Corner ( it looks like all they did is solder then heat shrinked 6 wires ) Whoa, I just noticed their Inverters are 3500 Hertz Connectors for the EL-Wire ( with these connectors one can solder to the inverter directly, No Splitter needed ) El-Wire 2.3 MM
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-02-2009 at 04:20 PM.. |
yep, im slow in the head
good info guys,
for attaching the "EL-Wire" to the case of the gauge, i have been pondering doing it w/ small pieces of stainless steel wire. i have seen people make there own "angle eye" set ups for head lights using small sections of wire to hold them in place cleanly. im thinking that if u get the "EL-Wire" to fit snugly into the gauge housing (aka having the start and end of it press against each other pushing it into the gauge housing) then restringing the "EL-Wire" in place w/ strategically placing thin strands of stainless steel wire should equate out to a clean permanent install of the "EL-Wire" with no worries of it coming loose from what ever "chemical bond" used to hold it in place coming free. the idea of having to drill holes into the case to run the wire will cause damage but, all this renders the gauges non OE style so im not too worried about it. im thinking of adding a "dimple" into the housing where the wire will go thur so the outside of the gauge housing is basically still "smooth" and easy to slide back into the dash. things may change when it comes time to install but so far this seems to be the way i hope to do mine. |
Wow, you guys have moved fast and really expanded on the idea nicely. It looks like this may be THE solution many of us have wanted! Nice job SpeedRacer.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
![]() I think for safe measure we need to place a Fuse before the inverters, what say you guys? What size?
This thread is just too cool not to follow--brainstorms happening by the second!
One question to the experimenters: on the speedo, you have the odometer numbers which are illuminated from behind the face. If you use just the wire, would that still light the numbers or would it be better to use the ELtape for that application?
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
My understanding is, if we route the EL WIRE thru the existing ports where the OEM light bulbs go then the lumination of the ELWIRE should emit light every where the OEM blub would have lit up.
This is why I am planning on using the EL WIRE instead of the EL Tape. I am sure the EL Tape could work but I am worried about the 90 bend it will need to take to wrap around and through the 3MM opening then bend to adhere to the walls of the guage without breaking or shorting due to possibly creasing/snapping at the bend. My 2 cents.
OK Fellas,
I found one more site http://www.thatscoolwire.com/store/cart_view.asp These guys have everything and shipping out of Texas: 6' EL-WIRE White 2.2MM Standard 5-Way Connector (1 Male 5 Female) 5 Male Connector 1 10-Pack End Cap (Clear) 12V Inverter for 1-8' Service (Raw, No adapter for Cig/Wall in Clear) $25.06 before S&H (Sorry Cali no Tax in Texas )I decided on 6 feet of wire due to the fact we'll need extra length to take up the depth of the guages. I roughly measured the spare clock's diameter and depth and got around 9". So just to insure I have enough EL-Wire. It would suck to be short on the last guage. You guys thinking of not using a inverter can but it will not be as bright. The exampe video is of an AC Direct Connect but you will get the idea:
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-02-2009 at 10:14 PM.. |
Happiest when Tinkering
AHH now you guys come up with this! This looks like it would have been alot easier than what I did but hey I like how mine turned out and if I have to redo later I will follow this and proly go this route. looks nice and is alot cheaper than I thought it was what were those other guys charging for this mod and why arent they chiming in here like they were hijacking the other threads.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
R&D guy
Location: the border between the states of inebriation & confusion
Very good - potentially a great solution.
I haven't received by EL wire yet, so I have (2) questions: 1. How much current does this draw? 2. How small a bend radius can the 2.3 mm EL wire tolerate? Is some kind of reinforcement possible (e.g. tight-fitting polymer tubing)? |
These splitters just hook the capacitors up in parallel. Of course when you do that you add the capacitances and the current goes up proportionally. Of course with higher frequency more current will be flowing and the light will be brighter. Edit: Is the tape you guys are buying rated (Vmax) to just plug in the wall socket to play with?
Rick 88 Cab Last edited by rick-l; 04-03-2009 at 11:32 AM.. |
Xc = 1 / 2 pi f C I = V / Xc Now if we could find out what C is per square inch.
Rick 88 Cab |
