Fuchs need stripping; no media blasting available here...
Hi Guys
I have a set of Fuchs ready for a new lease of life. Trouble is there is no media blasting (water and sand) service available where I live. Numerous posts here talk of media blasting as the the way to go. Is bead or soda blasting a safe option? Cheers James
1987 911 midnight blue, euro spec, 7&8 Fuchs, SW chip 2003 Fiat Multipla Don't blow a seal......literally. |
Soldier of Fortune
I wouldn't use beads, but soda is fine. Walnut shells. Crushed glass. Dry Ice. Those are all "environmentally safe"...which I'm assuming why they don't have sand blasting where you're at...?
Thanks for that.
Plenty of sand blasting available but I'm not so keen on this method as I have heard horror stories. There is a dry icer here. So this method is 'safe' for the wheels with minimal risk?
3.4 Bigger is better
Are you looking at just stripping the paint from the wheels? I would not use anything other than soda or dry ice. If the paint is all your looking to remove aircraft paint stripper works great and will not affect the anodizing on the wheels. Just make sure to wear the right protective gear as it will eat through nitrile gloves in about 10 min.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
You may have trouble finding it where you live, but I ended up finally using Aircraft stripper since all the previous stripper hardly did anything to the paint. I really never knew what made a particular stripper Aircraft but it definitely was more effective. One thing I also found was to put a heavy trash bag over the wheel surface after I put the stripper on, it seems to keep the stipper in contact with the paint longer and made it more effective.
Good luck
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Thanks Guys
I'm looking to take wheels back to a matt alloy finish, leave the rim raw (but protect with Vaseline?) and paint the centres satin black.
-Tucker The dry ice resource. |
