How to compression test again??
Can someone tell/remind me the important steps again on how to do a proper compression test, and on a cold engine??
damian
Old 04-05-2009, 10:35 PM
Home of the Whopper
It is pretty simple. Search for "compression test" and all will be revealed.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 04-06-2009, 06:37 AM
T77911S's Avatar
most say to do it hot, trying to get the hose to screw in takes a lot of time.
here is how i do it.
unplug CD unit
remove all 6 plugs
screw in adpater/hose into plug hole
you can hold the throttle wide open or keep it closed, just be consistant. i did not see enough difference to say to do one way or the other.
crank engine for 6 compression strokes. you will hear it.
watch the gauge, make sure it gets a good pressure increase each stroke. it helps with making sure your hose is not leaking and for a good check along with final reading.
i do 2 or 3 checks per, to make sure consistant readings for each cylinder.
now, if you can help me with the leak down tester i bought from HF
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-06-2009, 08:01 AM
Thanks T77.......I wasnt ssure if we removed all plugs or just the one to be tested...couldnt remember....thks ....damian
Old 04-06-2009, 09:43 AM
