Elombard's Avatar
Do not remove sparkplugs when engine is hot?
Makes total sense, might bring threads with you....I had never heard that until recently though....hence no hot leak down test.
What do folks think? I was searching and saw that one regular backs the plugs out cold and then leaves them in finger tight for the warm up prior to a leak test...not sure that is a good idea...
I have taken plugs out hot on previous cars a few times..guess I wont do that anymore.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-17-2009, 11:56 AM
a.k.a. G-man
Geronimo '74's Avatar
Originally Posted by Elombard View Post
What do folks think? I was searching and saw that one regular backs the plugs out cold and then leaves them in finger tight for the warm up prior to a leak test...not sure that is a good idea....
According to what I've read and heard, this is the way to go. Loosen carefully, tighten finger-tight ( or a bit more than just finger-tight) and loosen when warm to do leak down test.
Loosening in advance prevents damage to threads.
Old 04-17-2009, 12:11 PM
Elombard's Avatar
Makes sense, just a touch past finger tight and then a gentle drive to get it warmed up....I am just surprised with all the cars I have messed with that have aluminum heads that I never heard/thought of this??
Old 04-17-2009, 12:32 PM
crikey, i do it all the time. never had an issue. you get one now and then that is seized solid and it wouldn't have mattered if it was hot or cold. must be an old wife tale.
206 637 4071
Old 04-17-2009, 12:58 PM
Author of "101 Projects"
Wayne 962's Avatar
That's what I typically do. I don't see any problem with it. I like to break loose the plugs when they are cold. Even if there's no difference, it's easier to work on a cold engine, and you don't have that option of burning yourself.
-Wayne
Old 04-17-2009, 01:19 PM
Elombard's Avatar
How did I know JW would say that :-)
Good to know.
It probably comes down a lot to maintenance on the motor and has it been 5 years since the plugs were out...
This info came from a Pro Indy who has been working on air cooled P cars since 75. A lot of his work now is on race cars....
They must wait around a lot in the pits for the cars to cool off... :-)
Old 04-17-2009, 01:51 PM
FPB111's Avatar
So if I have a stuck bolt in aluminum I should freeze the aluminum and heat the bolt to help release it without damaging the threads?
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 04-17-2009, 04:02 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Hello,
25 years working on aircraft engines, never had a problem removing plugs hot or cold. The standard industry treatment is to put a small amount of Champion anti-seize on the 1st couple of threads. Costs about $8.00 at your local airport shop or from Aircraft Spruce. Been using it on everything that has sparkplugs from chainsaws to aircraft.
http://www.aircraftspruce.com/catalog/eppages/antiseize.php
Hola
eric
P.S. But I also use a torque wrench to tighten to factory specs.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-17-2009, 05:13 PM
++1,......
I've been pulling hot plugs out of engines (aluminum or iron) since the early sixties without any issues, unless someone else touched the thing and created a pre-existing problem.
John is right; just another Old Wive's Tale, and there are many,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
I prefer removing them when they are.. warm.
If thats possible.
Like after the car has sat for an hour or so after running. Of course that is not practical for a mechanic working on cars all day..
Not cold and not hot, but somewhere in between they seem to come out with the least effort and are less likely to bring some threads or a helicoil if there's one in there with them.
I put a little anti-seize on the threads but not so much that the sparkplug has a harder time grounding in the head.
Old 04-17-2009, 05:38 PM
signature65's Avatar
Checking you plugs when pipping hot is a great way to test your mixture if you dont have a CO reader.
I take my cars out for VERY spiritted runs and pulling over to pull a plug o check its color when hot. Been doing this for years.
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 04-17-2009, 08:36 PM
barney911rs's Avatar
May depend on how long they have been in and if a little anti-seize was used. Typically track cars have plugs checked/changed more often, so they will tend not to seize up and rip out the threads. My $.02
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 04-17-2009, 08:41 PM
Jim Williams's Avatar
+ 1 to what John and Steve said. Been taking them out hot for years to do hot compression tests, and never had any problems.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 04-18-2009, 07:57 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Originally Posted by jim williams View Post
+ 1 to what john and steve said. Been taking them out hot for years to do hot compression tests, and never had any problems.
+2...
Old 04-18-2009, 10:08 PM
Won Won is offline
Won's Avatar
No way. One might think that freezing the aluminum thread will make the metal "pull away" from the hole due to contraction and make the opening bigger but it's the opposite. A hole in a material with a positive coefficient of thermal expansion, i.e. metals, will contract when cooled, and expand when heated. Aluminum has higher CTE than steel so heating both should make removal easier. Going by this, a spark plug in hot/warm AL head should have a looser fit than it does when cold.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 04-19-2009, 02:11 AM
Elombard's Avatar
Won
if the aluminum expands more than the steel...wont the hole get smaller making it a tighter fit?
Old 04-19-2009, 05:16 AM
Won
This is a common misconception, one that even a lot of engineers struggle with. If the material expands, all the holes in it get bigger. The exception would be something physically constrained. If say you have a rubber seal captured in a gland. If the rubber swells, the hole in it will get smaller as ther is no place left to go.
'69 911 Targa w/ 3.2
Old 04-19-2009, 09:10 AM
Won
Remember your high school physcis class when the teacher demonstrated a metal ball could not pass through a metal loop? Then the teacher heated the loop over a burner and in a few seconds, the ball was able to pass easily through.
Think of the hole in the cylinder head as a loop. If the metal in a loop expands, the opening enlarges, same with the head.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-19-2009, 09:21 AM
Home of the Whopper
I haven't noticed much of a difference between a hot and cold leakdown test. Personally I would rather work in a cold engine bay. Plus I do leakdowns on engines sitting on pallets all the time too. Hard to get them warmed up. I am not saying one way is right or wrong, just my experience.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 04-19-2009, 09:39 AM
