porsher
Persistent Misfire, please help!
85 carrera, 3.2, stock motor (except for K&N filter). 200K miles.
Engine misfires during acceleration, small throttle opening and WOT. The engine stumbles and hesitates. It will reach redline and power seems strong. Idle is OK, overrun is OK. Checked/changed so far plugs dist cap rotor wires AFM Vacuum leaks (propane torch method) fuel pressure fuel injectors fuel filter A clue: I live out in the desert so it never really gets very cold, but last night the air temp was around 50F and it ran very much better, not perfect, but a distinct improvement. So what next?!? Chris L. |
What about your Bosch airflow meter system ?
Verify his plug and values , it's a common issue on our cars . Just an idea.
LIGHTER = FASTER !!! Last edited by cdrik915; 04-17-2009 at 12:35 PM.. |
porsher
I have already cleaned out the airflow meter and checked it's function as a voltage divider.
I also checked the temp sensor and the throttle position sensors. Maybe I will make up a test cable so I can monitor AFM function while actually driving. |
I have had a coil intermittently fail during acceleration and at higher rpms (4500 and up). couldn't find the problem until it failed completely. New coil...problem went away.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
porsher
porsher
OK so I tried a new coil.....and it's fixed.....err.......no it isn't........
It went from persistent to intermittent. Sometimes the engine will accelerate cleanly other times it will misfire. Balls! Nice idea though. Could it be the grounding of the coil...does the coil need to be grounded? Anything else worth a try? |
It might be a bad 02 sensor. Try unplugging it and see if it helps.
porsher
It's not the O2 senser.
I made up my test cable for the AFM so I could monitor its output while driving. All seems OK there - no erratic readings. Bastard. So now what? |
Have you checked gap/function of crank sensor(s)? Cleaning them and then ...
Regards,
Bernard |
Sounds almost like a fueling issue. You need to determine if it's fuel or ignition spark and narrow it down from there. Monitor your O2 sensor voltage and if it's too low (not including when it's misfiring) you may be running too lean. Too wide of a spark plug gap will make it also hard to fire under load. Also check the reference sensors for (a) gap and (b) wire deterioration. Check your head temp sensor too.
porsher
If they pass a resistance check they might still be putting out erratic signals, how can I check function while on the road? Lastly, does checking the gap/clean/replace require a motor drop??!? Cheers |
porsher
I thought so too. I have installed a fuel pressure gauge and the pump/reg/check valve are OK. I also had the injectors cleaned and checked the vacuum circuit. I'm not sure what else there is!?! I'll make up some test leads to monitor the o2 sensor. I have a wide band somewhere and a data logger. Plugs are OK. Temp sensor ohmed out correctly. I'll check the CPS and ref sensor. Cheers |
porsher
I pulled the harness off the ECM and performed electrical tests as described by Bentley
Crankshaft speed sensor = 1020 ohms Ref Sensor = 1010 ohms Both in range. The only unusual thing was a single brown wire pulled out of the harness with a connector on each end. The connectors were disconnected. I traced one wire to terminal 10 on the ECM which is assigned, bridge to ground California cars. The wiring diagram has it connected to the altitude correction box. So should it be connected or not? |
timeless beauty
Richen the fuel mixture 1/16 to 1/8 turn clockwise on the air box. With the cold/cooler temp you said it ran better, the CHT sensor must of registered the need for additional fuel. Does it run worse on humid days vs cool dry days? Could be a touch lean, Steve W I think nailed it.
Bob 87 targa |
Take it for what its worth, but I just fixed an odd misfire on a 3.2 for a buddy. The air boot that goes between the afm and the throttle body had some micro-fine cracks in it. Was just enough to let false air in and cause a misfire.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
porsher
I sniffed around the boot with a piece of tubing stuck in my ear, and sure enough all kinds of air flow could be heard. I loosened the clamps and gave the boot a medium tug, it tore in half ![]() I have a DE tomorrow so a friend was kind enough to lend me a spare, misfire fixed yay. But what a PITA. Thanks everyone for your contributions. |
Thanks in advance! |
