KNS KNS is offline
Torque values for front stoneguard
I'm reattaching the front stoneguard (underneath the steering rack). the Bentley Manual says that the rear Allen is 35 ft lbs, I can believe that. But it states that the front Hex nut is only 21 ft lbs. That seems awfully low for a suspension piece. Can anyone confirm this? I know the Bentley has several mistakes.
Kurt
Old 06-08-2011, 12:09 PM
KTL KTL is offline
Schleprock
KTL's Avatar
That 21 ft-lb number is correct. It's not really a suspension piece per se'. These fasteners are used to install two braces that add stiffness to the chassis at that location. The hump in the chassis for the steering gear reduces stiffness there, so the braces help make up for that.
Kevin L
'86 Carrera "Larry"
Old 06-08-2011, 12:59 PM
Member 911 Anonymous
DRACO A5OG's Avatar
21 nut
35 allen bolt
There alot of low torque settings per PAG/Bentley, I know how you feel FORD or Toyota would have been 100 lbs
Take care to insure they do not cross thread
'85 Carrera Targa
PCA/POC
Old 06-08-2011, 01:23 PM
KNS KNS is offline
Got it, thanks guys...
Kurt
Old 06-08-2011, 03:09 PM
