Designer King
What to replace when repairing airbox?
It looks like I'll be removing my airbox soon to check for breaks. If I can fix it, I will. Otherwise, I'll replace it. What should I replace when I do this?
Popoff Valve, if the new one doesn't have one Intake runner boots CSV and seal Airbox Seal Coffin Gasket (?) Anything else I should replace?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 04-19-2009 at 08:54 AM.. |
Paul,
With the air box off, check all hoses that typically are unseen--those between the engine and the firewall. Look closely for age and cracks and replace any suspect hoses to the CIS components, especially the large hose to the AAV and AAR.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 04-19-2009 at 08:38 AM.. |
the sleeves that connect the air box to the aluminum intake pipes are often shot. Be careful when ordering there are different sizes.
