Broken Rear sway bar mount
I heard a rear suspension clunk and got underneath and found the right rear sway bar mount has broken loose. I haven't gotten it up in the air yet but it looks like the screws may have broken. Has anyone here on the forum had any experience with this repair? Your help is appreciated!
Old 05-09-2009, 12:24 PM
Autodidactic user
David E. Clark's Avatar
Here are a couple of threads describing the repair:
Rear sway bar bracket broken, help!
Another great WEVO product: rear swaybar mounts
WEVO Sway Bar Bracket Install mod
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 05-09-2009, 12:35 PM
Jupiter 911
bklyn's Avatar
Found I had the same problem a couple of weeks ago, I ordered the sway bar bracket along with a new 20mm bushing and clamp from our host. Had to cut and grid the bracket from the frame, after that I had a local shop weld the new one in place. Most of time its the bracket that gives way or rust out and needs to be replaced. N ot a hard job but I dont weld.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 05-09-2009, 12:39 PM
I appreciate the help! I am a newbie and am having trouble learning how to search a topic on this great site. Does anyone have any suggestions? Many thanks!
1987 Targa just about to hit 29k
2004 mazdaspeed miata wifes
1995 spec miata SOLD stupid fun!
Old 05-09-2009, 02:51 PM
I did it on mine this winter took about 45 minutes start to finish though I have all the right tools
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-09-2009, 02:53 PM
stock one broke soon after I got my car years ago
r&r with one that was "OEM"
that one broke soon after
r&r with WEVO, no problems since.
WEVO is the way to go as most would say in this forum
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 05-09-2009, 02:54 PM
Diss Member
Quicksilver's Avatar
Lets go straight to the source. The WEVO RARB Console (rear antiroll bar mount...) is the solution of choice. The Porsche replacement mount can still break. The WEVO unit is bomb proof.
Pelican sells them here... Product Information: WVO-RARB
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-09-2009, 03:35 PM
Autodidactic user
The search function of this site is a great feature. Here is a link to the frequently asked questions section of this site. You probably won't want to muddle through the entire section but a quick scan will be helpful.
Once you have the general idea, click the search button on the blue bar about 1/3 way down the page. Click the down arrow next to "search" and then click advanced search. Put your search terms where it says "Search by Keyword." It's pretty intuitive - all you really need to do is play with the search function a little and you'll soon be a pro. I always try to use specific search terms like "sway bar repair" or "broken sway bar mount." You can limit your search to specific forums, like the 911 technical forum (on the right where it says "Search in Forum(s)"), to get more useful results. You can also limit your search by choosing some of the other functions on the page. For example, choosing to limit searches to threads with at least 5 replies will normally gets you more useful results. If you are searching for a popular search term, like "fuel injection" or "electrical" limiting your search to thread titles (directly under "Keyword(s)") is helpful. Welcome to the site, you'll find lots of help around here.
Old 05-09-2009, 05:47 PM
Zeke's Avatar
The main thing to know about searches is to use the word 'and' between your terms. This will produce results than contain all of your search terms, not just the individual ones. I don't think the search function has ever been adequately explained.
Old 05-09-2009, 06:10 PM
