Throw it on the ground!
GA Emissions/ Cat Bypass/ SW Chip Question
I'm due for my annual emission test in June, the first since installing an M&K cat bypass and SW Chip. I will be re-installing the cat for the test. Question is: Will I be OK testing with the SW Chip or should I swap back to OEM chip?
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
My SW chip passes in Texas. I do put the cat back. Done this for several years. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
That was the answer I was looking for. Do you re-use your exhaust gaskets?
Thanks!
Yes, for better or worse. No problems though. I even use old ugly HW so it looks unmolested.
