Fixing POS problems.
Like many other poster on this board I have had to deal with Previous Owners Syndrome, even after 13 years of ownership!
My latest problem was a relatively simple to fix. The oil pressure switch started leaking more this winter. I suspect it was seeping for a while. The leak dramatically accelerated in quantity this winter. I decided it was time for a replacement. I noticed a likely cause of the leak. If you look closely at the threads the first few are all mashed up. It was not cross threaded it was bottomed out on bad threads. Fortunately the adapter came out clean and easy with a 17 mm socket. I tightned up the old switch in the adapter and it would get to 15 lb ft of torque but the crush washer was not seated. There was some old teflon tape that I presume helped slow the flow of oil.
I used a 10 x 1.0 tap to clean up the threads on the adapter from the bottom up and everything looked OK. Everything torqued down nice and tight, and it had the solid feel of a proper fit on the new switch. The area had a good solid coating of crud. Overall it only added one hour to time to fix the problem properly.
So what is you favorite (or least favorite) POS problem you have encountered?
Old 04-28-2009, 06:03 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
the PO of my SC aparently drove the car thru wet asphalt AKA the "redneck undercoating system"
I may never get it all off and will probably go to another tub before its all over and done with
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 04-28-2009, 06:37 AM
