exc911ence's Avatar
1979 911SC "Frankencab"
Dave
Old 05-06-2009, 04:25 PM
If there's any chance you can get your insurance to pay for repair, I wouldn't go any further than opening up the sump plate to see if there is anything in the crank case or if its all external.
Of course, if you open the sump and have clearly thrown a rod or something then its game over.
Good luck.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 05-06-2009, 04:54 PM
Noticed something in the picture on post 52.. are there cracks on the next oil return tube socket?
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 05-06-2009, 05:09 PM
Zorin,
Sorry to hear of your latest engine issue.
I trust your recent threads where you were addressing oil and lubrication issues were purely of coincidence.
Low compression on #1
Dirty Oil! So soon?
Blue Smoke in Exhust
Switched to Valvoline VR, now low RPM
Get that sump plate off and see if there is evidence of further internal damage.
Paul
Old 05-06-2009, 05:43 PM
Send a message via Yahoo to jjrowe
Well, the bad news based on your other threads is that it looks like you got one of those Motormeister "10,000 mile" engines others have posted about. They look okay from the outside but then only last about 10,000 miles before they start burning oil and then often catastrophically failing. Upon disassembly you will probably find that the way it was put together was nothing short of criminal. I have no idea how that company is still in business.
I really hope that something hit it from the outside.
- Jesse
Old 05-06-2009, 07:21 PM
HarryD's Avatar
Is it just me, or am I seeing a Turbo case in a non-Turbo car?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-06-2009, 08:00 PM
dtw dtw is offline
GAFB
Nah not really; SCs and 3.2Cs used a 930 casting number for their cases.
I'm not buying the external damage theory, not for a second, but hope to be proven wrong.
If it is internal damage, I'd sell every single bit of the engine for parts (whatever can be salvaged), then start over with a good used motor or a rebuild candidate, depending on budget.
Trying to rebuild an engine that both grenaded that hard, and is also a MM rebuild, is just asking for trouble. I'm just sayin'.
Put it this way: years ago I was selling a worn out oil pump on eBay. I advertised it plainly as a spent, worn-out, useless oil pump. Figured someone might like to make some desktop art out of it.
Winning bidder: Roy @ MotorMeister.
Several BMWs
Old 05-06-2009, 08:16 PM
Talewinds's Avatar
88' Carrera, Black/Black/Black, "Murdered Out" OEM.
06' BMW 'M' Roadster (Wife's car and WAY faster than mine)
Old 05-06-2009, 08:22 PM
beepbeep's Avatar
just take of the sump plate and take a look with a flashlight. You might see a spun bearing and loose rod cap. Loose cap probably hit the case and took a chunk. Unfortunately, this means that piston is stationary and valve damage occured. If you are lucky, it would just be the rod bolts that snapped or got loose. That means that crank bearing might have survived.
worst case: crank, case half, one piston, two valves and two rockers will need to be replaced.
Thank you for your time,
Old 05-07-2009, 12:07 AM
UNDER CONSTRUCTION!
carrera turbo's Avatar
im not buying the impact theory as well. this is clearly something inside the motor wanting out and it seems that it almost made it.
oh by the way this damage is from the rod on the other side of the motor not the one close to the return tube in the pics. as the other side rod is directly inline with what we are seeing.
if you try to claim this as insurance they will have a shop verify the theory. and if it something on the inside you will be stuck with the bill. if you tear into it and find there is nothing wrong inside stop and call insurance and tell them the truth.you have no idea what happened but you must have hit something.
its all hub hub till you look inside
so look inside as the suspense is killing me.
pull the oil tube and see what you find.
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 05-07-2009, 12:36 AM
scarceller's Avatar
I 2nd the vote to simply crush the oil return tube and remove it. If that crack was caused from the inside I'd bet you'll get a good idea of why just by looking in the oil return port for that tube.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 05-07-2009, 05:49 AM
mca mca is offline
mca's Avatar
Little bit OT but I was wondering what that bolt was for? I don't recall using anything like that on mine and don't recall the heads having anything of the sort. But my memory isn't the best.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 05-07-2009, 07:28 AM
That bolt is plugging the air-injection port for the smog pump. Pretty common on heads between 73 and 80.
Old 05-07-2009, 07:31 AM
Now in 993 land ...
aigel's Avatar
Zorin: Sorry for your misfortune! But now please take the sump plate and the oil return tube off. This will take 10 minutes. Then please report back.
IMHO there is no way road debris or a compressed oil return tube would cause such damage. Those cases are very strong. This got smacked from the inside. There is no other explanation why you have a rod knock when you start the engine either.
Good luck showing this to your insurance convincing them "something in the road caused this crack, then I got oil starvation and internal engine damage".
Good Luck!
George
81 SC (sold)
Old 05-07-2009, 08:18 AM
zorin's Avatar
I will take out the sump plate today and report back.
Regardless, I think I rather just get another engine and use my existing intake systems (carbs) and exhaust (don't have any catalytic converter). I am not sure I will be patient and meticulous enough to assemble pistons/cylinder/rings into an engine. I have ready threads in this forum that people had their newly rebuilt engine burn great amount of oil. Is it that hard of a job?
Zorin
'79 911 SC Targa, 3.2L Carrera engine - Zenith Carbs - 36mm vents, Lightweight Flywheel and PP
'00 BMW 540i - Sports Package (The Beast)
'99 LandRover Disco
Old 05-07-2009, 10:03 AM
mca mca is offline
mca's Avatar
Zorin,
You seem to have a great attitude about this ("busted engine" in your sig).
Before you try to make more decisions we need to know what happened. Then the pros here can help you with the next steps - what to keep, what to toss, etc.
Old 05-07-2009, 10:13 AM
Carbon Emitter
jkarolyi's Avatar
Ahhhhhh...my heart sank when I saw the pictures of the Red Fan of Death!!! Judging by the MM rebuild and your other threads, I believe your engine has serious internal issues. You are one of many vicitims of the scheisters. Here's my collection of the other MM threads:
The $20,000 3.6 (actually more like 3.4) big bore upgrade to a 3.2 without upgrading the 3.2 crank!:
So, want to see what a $17,000 MM rebuild looks like
The complete 930 3.3 turbo engine taken in trade (w/no core credit) for a 2.7 mag case with Zeniths and used parts:
This will be LOADS of fun... :\ A MM special
The $20,000+ 2.7 rebuild which had to be done over by another shop:
My Motormeister Story (Two Parts - Long)
The 934 mile engine, all leakdown at 70% or more:
Motor Meister The Real Truth !
More cringe-inducing experiences:
http://forums.pelicanparts.com/showt...ter#post365065
Motor Meister strikes again
Att all people hurt by MotorMeister
http://www.ripoffreport.com/reports/...off0186445.htm
Old 05-07-2009, 10:38 AM
zorin's Avatar
what the ...?
Where did that nut come from?
Zorin
'99 LandRover Disco
Old 05-07-2009, 03:59 PM
3 restos WIP = psycho
kenikh's Avatar
Jiminy F--k-n' Christmas. That looks like the day after a nuclear holocaust. The case is toast; the webbing is totally smashed inside. Damn damn damn.
We all are crying inside for you.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-07-2009, 04:03 PM
m110's Avatar
Wow, appears to be the fatal damage of a rod.
1988 Carrera Coupe
Old 05-07-2009, 04:05 PM
