Thanks for everybody's help and excellent advice.
I found other engines. A rebuilt one for $5K and a used one for $3K . I am not sure where it was rebuilt , I will find out tomorrow. I am inclined toward getting the used one once I find out how many km it has on it and the result of compression and leakdown test. What numbers does the serial number should include to indicate that it is a long block 3L engine? I need to make sure before it is shipped from Montreal. I miss driving the my 911. I am addicted badly. I am already showing some signs of withdrawal! I will start dropping (pun intended) the engine this weekend or next.
Zorin '79 911 SC Targa, 3.2L Carrera engine - Zenith Carbs - 36mm vents, Lightweight Flywheel and PP '00 BMW 540i - Sports Package (The Beast) '99 LandRover Disco |
I think I just threw-up a little...
I too would love to see a tear-down of whats left. There's got to be some parts worth salvaging and out of morbid curiosity I'd like to see what what else happened. I'm not sure your budget, but if I was in your position, I'd avoid rushing right into a new engine and instead poll the experts here (of which I'm certainly not one) to try and get a motor with a known history or one that was rebuilt by someone with a solid reputation. Good luck with the replacement engine.
Don't Lift... Don't Lift... Don't Lift ![]() ![]() ![]() '75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade. |
Free minder
Once you pull the valve covers, you will be able to see if the nut came from there. The nuts that secure the cam tower to the heads are special oval nuts that deform when tightened and can only be used once. Many of the nuts inside the engine are like that. This is designed exactly to prevent them from getting loose inside and cause catastrophic failure. I wouldn`t be surprised if MM either reused an oval nut, or used a regular nut.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
UNDER CONSTRUCTION!
didnt want to just jump up and say rod.all things surface in due time. ed
Sometimes the first thing that comes to mind should be the last thing that you do! ![]() |
I still believe that your rod cap got loose. Nut probably came from rod cap...it might have vibrated loose due to improper torque used to tighten it.
Thank you for your time, |
you see Arthur...
Zorin,
So sorry to see that. Why not give the guys at Nineapart a call. Last time I contacted them they had a low milage 3.2 for 6500 CDN. Good time to upgrade. Just a thought. I really admire how well you are dealing with the busted motor. Good luck.
J 82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat 06 Cayenne S 00 ML 55 AMG Santa Cruz Bullit |
Slumlord
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
That is amazing and heartbreaking at the same time. My sympathies Zorin. That is the first time I have ever seen a rod failure do this. It looks like it whacked the oil baffle/case webbing just right to pop out the aluminum case around the oil return tube. Sorry to see that man...Salvage the good parts off of this motor & keep the case as a conversation piece/coffee table.
FC '73 911 Track Car '99 996 Daily Driver '93 968 Wife's Car '05 Cayanne S Family Car |
![]() Is that the rod nut? To me it seems to still be in place. Hard to tell though.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
That nut came from the motor next to yours at Motor-sheister. The guy dropped it in there when he spilled his coffee in it....just a guess....
tk 08 911 C2S - Sold 13 Audi A4 14 Jeep SRT 500HP |
I realize all the MM hatred.. but you guys are making huge assumptions here pretty unfairly I might add. I scientific tear down would be interesting but just a lot of bashing with no basis here so far. that nut could have easily come off after the rod let loose.. not necessarily before.
Why not do something constructive and prove what caused this instead of blaming.. I mean MM is still in business and they have a ton of motors out there.. this could have easily been driver error.. low oil.. wrong oil.. even a over rev could have caused this (though not probable).. also.. is it possible that he did hit something and loss of oil created the rod failure.. I dont see any bluing on the rod so Im guessing not.. but a thought. anyway.. this would be interesting to prove a few things.. like what about head gaskets?? and here is one.. check those tubes.. are they loose or tight?? They should turn pretty easy.. and wiggle back and forth a little. Again, I know about the hatred but cmon.. lets look at this a little more logically.. while this sucks for the owner its a great opportunity to learn.. and if he doesnt want to do the tear down Im guessing some guy near him will do it for free.. THEN we can bash MM.. lol.. or not.. who knows?
JP '76 911s Ice Green Metallic bone stock |
A nut in the bottom of the pan is a bad thing BUT may not be the cause of this damage. That nut does not look crushed in any way.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Carbon Emitter
"Why not do something constructive and prove what caused this instead of blaming.. I mean MM is still in business and they have a ton of motors out there.. this could have easily been driver error.. low oil.. wrong oil.. even a over rev could have caused this"
Roy? Is that you? ![]() |
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
abit off center
When you get the rods out see if they shimmed the bearings with newspaper to snug them up!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Slumlord
I'll do it. I PM'ed him but never heard back...
UNDER CONSTRUCTION!
![]() ed
Registered lurker
Wow, people defending Motorshiester.....
Jeff '79 Widebody SC |
I think it's just one person.
'85 RoW 911 Coupe '65 356 SC '72 BMW 2002Tii '10 Cayenne '20 Ram Longhorn |
