Broken Rear sway bar mount
I heard a rear suspension clunk and got underneath and found the right rear sway bar mount has broken loose. I haven't gotten it up in the air yet but it looks like the screws may have broken. Has anyone here on the forum had any experience with this repair? Your help is appreciated!
Autodidactic user
Here are a couple of threads describing the repair:
Rear sway bar bracket broken, help! Another great WEVO product: rear swaybar mounts WEVO Sway Bar Bracket Install mod
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
Jupiter 911
Found I had the same problem a couple of weeks ago, I ordered the sway bar bracket along with a new 20mm bushing and clamp from our host. Had to cut and grid the bracket from the frame, after that I had a local shop weld the new one in place. Most of time its the bracket that gives way or rust out and needs to be replaced. N ot a hard job but I dont weld.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
I appreciate the help! I am a newbie and am having trouble learning how to search a topic on this great site. Does anyone have any suggestions? Many thanks!
1987 Targa just about to hit 29k 2004 mazdaspeed miata wifes 1995 spec miata SOLD stupid fun! |
I did it on mine this winter took about 45 minutes start to finish though I have all the right tools
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
stock one broke soon after I got my car years ago
r&r with one that was "OEM" that one broke soon after r&r with WEVO, no problems since. WEVO is the way to go as most would say in this forum
1989 Carrera 3.2 Silver Anniversary Edition 2007 BMW 750Li 2005 Honda Odyssey EX-L http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html |
Diss Member
Lets go straight to the source. The WEVO RARB Console (rear antiroll bar mount...) is the solution of choice. The Porsche replacement mount can still break. The WEVO unit is bomb proof.
Pelican sells them here... Product Information: WVO-RARB
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Autodidactic user
The search function of this site is a great feature. Here is a link to the frequently asked questions section of this site. You probably won't want to muddle through the entire section but a quick scan will be helpful. Once you have the general idea, click the search button on the blue bar about 1/3 way down the page. Click the down arrow next to "search" and then click advanced search. Put your search terms where it says "Search by Keyword." It's pretty intuitive - all you really need to do is play with the search function a little and you'll soon be a pro. I always try to use specific search terms like "sway bar repair" or "broken sway bar mount." You can limit your search to specific forums, like the 911 technical forum (on the right where it says "Search in Forum(s)"), to get more useful results. You can also limit your search by choosing some of the other functions on the page. For example, choosing to limit searches to threads with at least 5 replies will normally gets you more useful results. If you are searching for a popular search term, like "fuel injection" or "electrical" limiting your search to thread titles (directly under "Keyword(s)") is helpful. Welcome to the site, you'll find lots of help around here.
