I received a PM from pksystems regarding how I ran the G50 hydraulic clutch tube through the tunnel. I wasn't able to send pictures via PM so am posting it here.
![]() ![]() I need to update this post - its been a while..
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html 930 Cab - ex-IA car, 3.4L, 1.2 bar, G50 996 Turbo - X50. |
300hp 1800lbs is the goal
tks... subbed
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Not Royce
Congratulations on building a dream car! The effort and patience must have paid off real good!
I love every detail that you have worked on and it sounds ridiculous! I had a question about the BBS wheels you are running. I will be doing a Narrow RSR RWB in the near future and i'd like to use a similar setup as the wheel fenders seem to have similar clearance. Could you tell me the size and calliper clearance ?
Pistache: 1984 911 backdate @RWB_Royze on IG www.instagram.com/rwb_royze RWB Japan/Middle-East representative |
Guest
Posts: n/a
This is absolutely amazing! Sub'd!
It is the work, patience and love like this that the rest of us can even begin to believe. I took the engine out of my stock 86 ten years ago to replace the clutch, and after collecting parts I am going to perform a mild upgrade to the suspension and brakes.
Richard. You do beautiful work. I found this thread by a search on the word Tarret. I needed some visualization of the through chassis sway bar before I could "get It" Thanks for the great pictures. Question. what is your photography setup. Thanks, RickP |
