Question Help with rough idle problems
http://www.youtube.com/watch?v=ITi_8FpeGLs
Any ideas?
-Scott
Old 04-24-2009, 08:40 PM
911SC Hobbyist
Man that thing can't be running on but about three cylinders.
did you pull the plugs one at a time and see if there was spark on all the plugs?
Old 04-24-2009, 09:06 PM
steely's Avatar
Agreed, it's more than just an idle issue.
I'd look at everything - check the plugs, the ignition wires, intake runner nuts to make sure your not leaking there, vacuum lines. Does it die by itself? Did this just start happening?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-24-2009, 09:22 PM
Certainly running on 4 or less. I would start with
1. Ignition leads, plugs
2. Injectors.
I would first look for cylinder specific items - that is same cylinders that are not working.
At this time NOT issues that effect all cylinders - coil - fuel - Motronic items - etc.
Where would I start - item 1 above - plugs first just cause it is simple and cheapest.
Examine all plug tips for further clues.
Paul
Old 04-24-2009, 11:03 PM
muck-raker
kidrock's Avatar
2. Injectors.
Paul
+1...except, these would be my second steps. The very first (and easiest) thing I would do would be to spray around every single intake and vacuum and check for intake leaks. Cheap, easy and takes approximately 1-2 minutes...and usually eliminates the problem.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-25-2009, 10:57 AM
Sounds a lot like my engine when I had my ignition wires crossed.
Old 04-25-2009, 06:07 PM
Virginia Rocks!
VaSteve's Avatar
+1, but you usually get back fires. At least with CIS you do....maybe Motronic is different?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 04-25-2009, 06:48 PM
Started pulling plugs and checking for spark. Only pulled 3 plugs, but all where very black but dry. There was spark, but didn't seem very strong. Ordered new distributor, cap, wires, plugs, and coil.
If that doesn't work any other ideas?
-Scott
Old 04-29-2009, 06:59 AM
I replaced the plugs, wires, distrubutor cap and rotor, and coil. Ran much better but still not 100%. Felt and sounded like it was on only 5 cyclinders.
A friend took at it, and with stethascope found one of the injectors to be almost dead (hardly any noise coming from it). He swapped locations to make sure it was the wiring and it didn't work in the new location either so definately a bad injector.
I've got an event next Friday, so I need a new one by Wed. Pelican has them like $280. Is there anywhere you can get them cheaper. A friend told me you can use a Buick injector? Any ideas about that? I just need for the track event Fri, until I can get mine sent out to be cleaned.
-Scott
Old 05-10-2009, 07:11 AM
