Throw it on the ground!
Clutch Bleeding Question
I don't have a pressure bleeder and have seen some home made versions using a spare resovior cap which I don't have. I'd really like to rig something up tonight to give pressure bleeding a try on the clutch slave with the pedal in the up position. I've try bleeding several times now pumping the pedal the old fashioned way with no success. I think I've still got some air in the line.
What about pulling off the over flow tube and about rigging up some tubing and air line fitings to pressurize at the overflow nipple rather than the cap? Any reason why that won't work? Anyone know the size of the nipple so I can pick up the right sized tubing & fitings on the way home?
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 05-13-2009, 08:09 AM
KTL KTL is offline
Schleprock
KTL's Avatar
You certainly can use the overflow nipple location. The hose size listed in the parts diagrams appears to show the plastic tube that the overflow hose connects to is 5mm OD and 3mm ID? That sounds about right. I'd get some ~5mm ID hose and give it a try.
I've seen some people use garden sprayers for pressure bleeding. Also, don't forget you can vaccuum bleed the slave. You can probably pick up an el cheapo vaccuum bleeding kit from your local auto parts store like AutoZone.
Kevin L
'86 Carrera "Larry"
Old 05-13-2009, 09:52 AM
Just completed bleeding the slave by pressuring through the overflow nipple and it worked great! The cap has a vent hole that will atomize the brake fluid if the pressure is set too high. About 20 psi seemed to work the best using this method.
Mark
1987 911 Coupe
Old 05-13-2009, 06:33 PM
Just completed bleeding the slave by pressuring through the overflow nipple and it worked great! The cap has a vent hole that will atomize the brake fluid if the pressure is set too high. About 20 psi seemed to work best using this method.
Mark
1987 911 Coupe
Old 05-13-2009, 06:55 PM
aj88cab's Avatar
Mark
Wish I'd seen this sooner, I have a power bleeder you could have used. Sounds like you got it worked out though.
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 05-14-2009, 06:20 AM
Andrew, thanks for the offer!
Mark
1987 911 Coupe
Old 05-14-2009, 06:39 AM
aj88cab's Avatar
No Problem, next time you're doing brakes let me know...besides I might need a P234 tool one day soon
So when do you think you will be back on the road. If you're buttoning up CV joints...soon? By the way, where in Atlanta are you located.
Andrew
Old 05-14-2009, 07:47 AM
Andrew
Back on the road today! Now that I learned how to bleed the lines, I'll be doing my brake lines soon. Should probable replace my 22 year old rubber lines while I'm at it.
I'm in Roswell.
Mark
1987 911 Coupe
Old 05-14-2009, 08:50 AM
