PorscheGuy79's Avatar
Quick question, removing the front turn signal parking light.
How do you go about removing the from turn signal driving light bulb, no the actual indicator (push and turn) but the one with the 4 prongs on it. It is highly corroded and the blub itself broke out and now im trying to get the base of it out.
So what is it? Just pull? Twist? Screw out? Anybody?...Bueller?
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 05-14-2009, 02:38 PM
2Utes's Avatar
The front turn signal bulbs are a push and twist installation/removal. The twist seems to be just less than 90 degrees. Good luck with the broken base removal.
Jeff
'82SC Pacific Blue
'02 C4S Silver (Gone but fondly remembered)
'11 GTS Amethyst
Old 05-14-2009, 03:09 PM
Wash. State
nesslar's Avatar
Push the base in with a screwdriver, and grip and gently turn the base outer edge with a pair of needlenose pliers. Easy does it so as not to just mangle the base.
Edit: Am I right, or am I missing something here?
Old 05-14-2009, 03:27 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
Matt -- I did mine that way -- let me know if you need help.
-Tom
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 05-14-2009, 03:44 PM
Thanks guys! I got it out with a little PB and the twist and shout method, the little bugger was tough though. Unfortunately its not the light bulb, by the looks of it the bulb is not getting ground but out multi-meter turned out to have a fried fuse so we can verify that yet but anybody got any ideas on why its not grounding?
It was just working a couple days ago and I did clean up the terminals with some sandpaper and cleaner. Ideas?
Matthew
Old 05-15-2009, 11:22 AM
