Post Help! Potential CIS problem
Maybe someone a little bit more familiar with the 83 sc CIS system can help me out.
I start the car, idles at 2000 for about 30 seconds, then quickly drops to about 600 RPMs and runs a little rough.
When it reaches operating temp (after warm up), it idles nicely at 1000 rpms and runs fine.
do I have a problem? is "idle hunting" normal for these cars and since my car doesn't "hunt" indicate some type of problem?
thanks
Old 06-07-2001, 07:33 PM
Post
Mine seems to warm up in the same manner. IS your O2 sensor disconnected? 81SC
Old 06-07-2001, 08:23 PM
Post
where is the 02 sensor and what does it look like? thanks
Old 06-07-2001, 09:04 PM
Recreational Mechanic
Nickshu's Avatar
Post
Disconnect your O2 sensor and then reset the mixture using an EGA. The sensor is in the exhaust near the cat. Follow the wire thru the left engine sill to a connector on the left side of the engine compartment. Disconnect here.
If that doesn't solve the problem...then you can start looking at other sources. Makes sense though as the sensor doesn't start working until the head sensor (right cam cover) detects correct temp.
Good Luck
Nick
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
PCA -- Rocky Mtn. Region
Old 06-07-2001, 10:14 PM
