How do I replace the dashboard trim on a 71?
My 71 had been restored at one point and they used a thin wood strip instead of basketweave vinyl for the dash trim. I purchased replacement trim from our host but not sure how to install it. Can't find anything in search. Anyone done this already? Does the metal frame come off or do I have to just glue the strip in place with it attached to the dash.
Here is what's on the car now:
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 05-16-2009, 04:52 AM
on mine I took the thin metal plates off (very glued on) with care not to bend them then glued the new vinyl on and reglued in place. Make sure and tuck edges of vinyl around side edges of the plates so it doesn't lift off. Iff the plates were removed when the wood was put in you can probably use the wood, it should be easier to glue than the metal plates. Youll have to carefully take out the trim around the vent controls and take the ignition cover and light switch out.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-16-2009, 10:40 AM
thanks, what kind of glue did you use?
Sean
NASA GTS2
Old 05-16-2009, 11:40 AM
on the vinyl i used the spray on high tack trim glue from 3m or wurth, same for the plates.
1991 C2 Turbo
Old 05-16-2009, 11:47 AM
could you please post a picture of what your panels look like at the edges? Trying to get a reference for how to "wrap around" the side edges. Does it make the side edges stick up?
Sean
NASA GTS2
Old 05-17-2009, 08:08 AM
Classic's Avatar
The trim is glued on, and rapped around the edges about 5mm.
My trim was held on with double sided tape, Pet shows double sided tape used to attach the trim to the dash. That will also save the problem of it wanting to sit up at the edges.
Classic 1969 911T
Old 05-17-2009, 02:20 PM
robmog's Avatar
+1 on foam double stick tape about 1/4" wide
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 05-17-2009, 04:39 PM
AutoBahned
RWebb's Avatar
a blow by blow with pics might be nice
esp. since I want to do the same thing this summer...
Old 05-17-2009, 06:06 PM
signature65's Avatar
My 73s edges are lifting....so it all needs to be replaced too. Im curious about the wrapping. Pics would be awesome.
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 05-18-2009, 09:15 AM
