jake61
3.6 conversion help needed
Found a 95 3.6 motor to put into my 78
SC. Need advice on the best sources for conversion parts.Also any other advice on this project including possible hang-ups or just tips on making it go smoothly.Thank you all very much in advance.John Szabo |
John, there are many here that have done this conversion and a wealth of advice. Get a drink and use the search feature...try 3.6 upgrade or 3.6 and conversion. Good luck..it is a good upgrade and not too expensive. with engine, should be less than 10k.
1986 3.2 Carrera |
3.6
does original car have drive block?..coded key cut off.i think so..ecu has to be modified!!pricy
jake61
Murf the 95 motor does not have the drive block.You are right though on 96-97 motors it costs about $850 to get around this problem.Thanks John
