jake61
3.6 conversion help needed
Found a 95 3.6 motor to put into my 78
SC. Need advice on the best sources for conversion parts.Also any other advice on this project including possible hang-ups or just tips on making it go smoothly.Thank you all very much in advance.John Szabo
Old 05-17-2009, 05:44 AM
John, there are many here that have done this conversion and a wealth of advice. Get a drink and use the search feature...try 3.6 upgrade or 3.6 and conversion. Good luck..it is a good upgrade and not too expensive. with engine, should be less than 10k.
1986 3.2 Carrera
Old 05-17-2009, 05:55 AM
3.6
does original car have drive block?..coded key cut off.i think so..ecu has to be modified!!pricy
Old 05-17-2009, 06:33 AM
jake61
Murf the 95 motor does not have the drive block.You are right though on 96-97 motors it costs about $850 to get around this problem.Thanks John
Old 05-17-2009, 11:46 AM
