Gearbox leak from cover
Hi, i have recently discovered a gearbox leak which is coming from the rear cover. there appears to be a small crack in the cover that is now covered with JB weld or similar , (done by PO) but has now begun to leak. it is a 915 G/B with a 2.7 CIS.
i was planning an engine drop in the near future for inspection and cleaning and while the engine and G/B is out is it worth replacing the rear cover. is this a big job and how much would the cover cost. i presume it aint free!!! is this a common thing or does this indicate something wrong or excessive play inside the G/B. no issues with driving the car. thanks |
If it is the nose cover (front most piece), replacement is pretty easy. If it is the mid cover, replacement is an intermediate job requiring a 5/R gears removal. If it is the differential housing, replacement means having to rebuild the gear box and resetting the pinion depth. That is a job done by the most experienced or challenge seeking individuals.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
![]() sorry yes, its the nose cover.... |
Lucky dog. that is the easy one.
I'll make you an offer on my cover, but it's from an SC and I don't know if it fits.
