Decolliber's Avatar
replacing clutch slave bleeder valve
Part # 928-351-945-03. Mine is starting to get rounded off. Three questions:
1. when replacing it, do you need to bleed just the clutch or the entire braking systems as well?
2. if I am using a Motive power bleeder, does it matter if the clutch pedal is in or out when I bleed?
3. can the clutch bleeder screw be replaced by one of the speed bleeders for brake calipers that Pelican sells, or is the screw pitch different? The clutch bleeder screw takes a 7mm wrench and the brake bleeders an 8mm wrench, so I would imagine they might be incompatible.
John C
1988 911 Carrera coupe
2002 BMW 530
Old 05-22-2009, 08:10 AM
1. Just the clutch
2. I assume in needs to be in the "up" or non depressed position, at least that's the way I did it on my '88 and it worked perfectly.
3. no idea
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-22-2009, 08:46 AM
