Clutch Replace
I just finished installing a new clutch kit to replace the rubber center disc. I have the trans fit to the engine (it slide on easily) and the fork is fit to the throughout bearing. When I put it into gear and I can still turn the half shaft flange as if it wear in neutral. Have I missed something here?
Old 05-22-2009, 03:20 PM
Southern Class & Sass
Dixie's Avatar
Turning one of the drive shafts does not turn the input shaft. It results in the other drve shaft turning in the opposite direction (unless you have a limited-slip or spool).
Try turning the motor over with a wrench and see what happens...
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 05-22-2009, 04:37 PM
Thanks shortly after posting this I thought about the fact they might be turning in opposite directions and of course they were. All is well.
Old 05-22-2009, 05:27 PM
