Clutch Replace
I just finished installing a new clutch kit to replace the rubber center disc. I have the trans fit to the engine (it slide on easily) and the fork is fit to the throughout bearing. When I put it into gear and I can still turn the half shaft flange as if it wear in neutral. Have I missed something here?
Southern Class & Sass
Turning one of the drive shafts does not turn the input shaft. It results in the other drve shaft turning in the opposite direction (unless you have a limited-slip or spool).
Try turning the motor over with a wrench and see what happens...
Dixie Bradenton, FL 2013 Camaro ZL1 |
Thanks shortly after posting this I thought about the fact they might be turning in opposite directions and of course they were. All is well.
