Old 60's Porsche Tech
captainlewis's Avatar
85 carrera intake manifold gasket time a little help please?
I will be doing the intake manifold gaskets on my 85 carrera. I am planning to send my injectors out to witch hunter for rebuild. I am going to replace the bakelite spacers on the intake manifold also. The car has 174k on the clock what else should I be replacing while I have the intake manifolds off any suggestions? Oh yeah who is a good source to make the fuel line that goes under the manifold? thanks JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 03-05-2009, 08:19 AM
Peter Zimmermann's Avatar
If you also use the Rennlist Forums, check into the 911 Forum and send a pm to douglas bray - he did an engine compartment fuel line/manifold reseal on his 1988 Carrera. He had a pretty lengthy thread with pics for the project - you might find it helpful. Sorry, I tried to find the thread in order to give you a link, but I can not remember the thread title.
Keep the Shiny Side UP!
Pete Z.
Old 03-05-2009, 09:28 AM
Why would you be replacing the bakelite spacers?
Old 03-05-2009, 05:43 PM
jrumiano's Avatar
Since you're going to remove the intake manifold you'll have lots of room to replace the oil breather cover gasket and the oil pressure warning switch (both are prone to oil leaks). Regarding the spacers, unless they are very warped, you should be able to reuse them. If they are slightly warped you can use a flat surface and some 150 grit sand paper to sand and level them. You may also want to clean the intake manifold, more then likely you'll find traces of oil reside on the inside.
Good luck,
John
Old 03-05-2009, 09:01 PM
Will the engine be in the car?
If so do you have a plan to clean the intake gaskets off the head?
Rick
88 Cab
Old 03-05-2009, 10:04 PM
this has to be one of the worst jobs to do with engine in the car. When i did this, i didn't want to remove the intake studs and those effin intake gaskets were like bonded to the head. Gasket remover was only marginally successful. i would make damn sure i had an intake leak or i would drop the motor...fwiw.
Old 03-06-2009, 03:12 PM
Wer bremst verliert
JohnJL's Avatar
Place rags in the intakes and remember to remove them. As noted, you only need to replace the spacers if they're cracked. Otherwise sand em flat.
Other while-you-are-in-theres include fuel filter replacement, air filter replacement, thoroughly clean, grind and re-install the grounds.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-06-2009, 10:06 PM
charlesbahn's Avatar
Yea, getting the old gasket material off is a PIA, especially with the engine in the car. You have to 100% successful, or you have big leaks that are worse than when you started.
I was successful but it took a long time and a lot of patience. I found that liberal use of "strip ease" gel paint remover on the baked on gasket material was required to soften them up so they could be scraped off (rags in the intakes as above, remember to remove). I finished it by polishing the cleaned surface with a dremel polishing pad and polishing compound. Looked nice and felt good when done, but it was a hell of a job.
Charles
Old 03-07-2009, 06:08 AM
Throw it on the ground!
Have you completed this and if so how did it go? I've got an intake leak on #2 and will be replacing the gaskets on 1, 2 & 3. After reading this post, it doesn't sound like a fun job. I just complted a swap and decided not to replace the intake gaskets while the engine was out (you've got to draw the line somehwere!). I had a heck of a time removing the old gaskets on the chain box covers.....this sounds similar.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 06-01-2009, 09:30 AM
I replaced the gaskets about 3 years ago when I changed the fuel line and all is well. I did it over a couple of weekends since working on the car was supposed to be fun.
The problem is the fan shroud goes over the intake and you are scraping the gaskets out of a hole. The metal is also very soft.
Buy some gasket remover and some conforming safety glasses since your eye will literally be 5 inches from the front intake hole.
Rick
88 Cab
Old 06-01-2009, 11:16 AM
