72 four door's Avatar
72 window help
Am in the process of installing a driver side door/window frame and the glass separated from the track that it lays in. The old rubber is worn out. Does pelican sell that rubber ? Or should I use something else?
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 05-30-2009, 01:04 PM
cfc cfc is offline
rubber
Why not call Pelican and ask?
Old 05-30-2009, 04:50 PM
Cause I looked it up on pelican and couldn't find it and was hoping someone might know! And its sat and pelican is CLOSED. Can I get a response from people in the know, Thanks
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 05-30-2009, 06:30 PM
If you're talking about the channel that the bottom edge of the door glass sits in, there's a universal composite tape that lays in the channel, and the channel is then lightly tapped onto the glass. You don't need a Porsche part, check with an auto glass shop near you, they should be able to supply some.
Where in NJ are you?
Dave
1969 911T Coupe
1972 911E Targa
Old 05-30-2009, 07:26 PM
Yup try the tape had the same problem on the drivers side
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 06-02-2009, 03:30 PM
