Glove box locked or Jammed; how should I open......
I have a 1973 T.
The original key has never been able to lock or unlock the glove box. Today, I can not get the box open. I do not know if it is the lock or if it is just jammed. Though it does not seem jammed. Not a crisis but given the contents I need to eventually open. How do I get in? Remove the knee bar and unscrew the door? Locksmith? I do not want to create unnecessary damage. This must be a security feature I never heard about; clear 120mph and the glove box automatically locks!
63 356 2.1 Rally Coupe 75 911M 2.7 MFI 86 Sports Purpose Carrera "O4" 19 991.2 S Last edited by Macroni; 06-07-2009 at 08:13 AM.. |
Regis turd ab user
Try inserting a thin but still firm feeler blade in from the side of the knob at the top of the door, and then over the top of the knob to depress the retaining tab down. Your plastic tab is most likely broken.
Thanks... now I need to find my feeler guages.....
63 356 2.1 Rally Coupe 75 911M 2.7 MFI 86 Sports Purpose Carrera "O4" 19 991.2 S |
Couldn't do it. Locksmith?
Sportomatic 4 the People
How odd, Luke, I have the same problem. Subscribed!
Ed
1970 911T Sporto coupe 2016 E350 4Matic Sport wagon |
I think I know exactly what happened (been down this road before).
When you're twisting the knob the "finger" that does the locking is not retracting far enough into the lock. The catch is that NOTHING will reach it to pry it down. The lock will have to be replaced when you do get it open. On the bright side, I believe the finger is plastic ... I had to grab knob with a pair of special pliers, twist, and then pull like hell ... eventually the lock broke and we were able to find the 10 years of back registrations and doo-dads that were time capsuled in my friend's glovebox. |
cycling has-been
I don't think it's possible to unscrew the door from the outside, even with the knee pad removed.
I drilled two 3/8 inch holes in the bottom of the box. One for a long screwdriver, the other for a flashlight and sight hole. You can poke the blade of the screwdriver up there and release the latch from the inside. If you choose, the box can be replaced with no noticeable after-effects. (this was on my 73) Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Registered knucklehead
I would do as bkreigsr suggested and wish I had checked here when mine broke on me. If you want instead of cutting two small holes you can cut as big a hole as you want and stick your hole hand in if you want. I cut the strap from under the dash holding the box in thinking I could just replace it cheaper than the box itself....DO NOT CUT THE STRAP!!! The strap is welded to the bottom of the dash top and not easily replaced....
Just cut hole in plastic glove box to gain access to back side of lock to pop open. Then replace box, many for sale here used and fix/ replace lock. My latch on the lock was made of metal so I am not sure that Mr9146's suggestion of yanking on it with a pair of pliers would have worked for me.. Gregg
1983 911 SC Cabriolet, 1989 944 S2 1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455 2000 BMW 528i Touring, 2005 GMC Sierra Last edited by 83-911SC cab; 06-09-2009 at 07:46 AM.. Reason: update |
Just unscrew the strap that holds the box in place.....you should be able to get a 10mm or 13mm socket way up there and take the whole box out from the hood side.
Darren 1973 911 T MFI 2005 997 Carrera 2001 Toyota 4Runner |
just force it to turn. the whole lock will rotate catch and all.
Been there done that. Chris 73 911 E |
Cut the strap, pull the box out, and reach the lock from behind. Use a 1/2" x 2" piece of aluminum and four pop rivets to "restore" the strap. No one will ever know.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
He wants to minimize damage.
Neither his box or strap are damaged ... the lock is (obviously). Therefore, the only part that should be sacrificed in this case is the lock itself. Why destroy something that you don't have to destory? ![]() Luke, I showed you what to do ... go for it.
I don't mean to step on toes here...When my lock would not operate, the mechanism inside the lock itself broke so no matter how much I twisted and pulled, the latch would not move an iota. Thus not allowing you to yank it open.
If the latching part is moving but just not enough to release then I would figure the twist and yank could work. Also I just repaired my strap (that I cut in half to remove my glove box) by riveting it back together. While I was doing this I noticed that my lock and catch were not actually inside the glove box but more on top and to the left of it. Do not know if yours is different. But it looked like I could have used a long U-shaped stiff rod along with a lot of praying and fiddling to pop the latch.
1983 911 SC Cabriolet, 1989 944 S2 1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455 2000 BMW 528i Touring, 2005 GMC Sierra |
The feeler gauge approach isn't working for me. Luke, any luck? Ed
cycling has-been
On the 73, I drilled the holes about 1 1/2 inches in from the door, spaced 3 inches apart, in the center of the box, under the knob.
No amount of twisting or pulling from the outside is going to release the door (without destroying it) if the plastic tongue has separated from the lock mechanism, as was the case with mine. The guts of the lock are only white metal and mine just gave up after 29 years. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 06-11-2009 at 12:42 PM.. |
I tried the feeler, Ed, no luck. I will not try anything until Saturday. Damn what a PIA.
The lock may not be damaged. It could be that the large nut (forget this size) that holds the lock in place came loose. What gives me a clue that his is what might have happend is the horizontal position of the key slot in the pic. IIRC, it should be vertical. That happened to me once, but luckily was able to get the door open. When I tightened that nut, you can betcher donkey I used some blue loctite...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 06-11-2009 at 07:05 PM.. |
However, in the all times that I've see that happen over the years, the whole lock assembly would rotate and the glovebox would open. The issue with those cars was keeping the glovebox closed ... not getting it open. |
