anyway to get key for car alarm system?
I have ignition/door key but not the key that goes inside the door to turn on/off the Porsche car alarm...is there anyone who knows of a resource to figure out how to get a key to fit? Short of getting a replacement key, is the only other option to rip out the current key switch and replace?
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 06-07-2009, 09:55 AM
Mitch Leland's Avatar
I'm sure a master locksmith could probably duplicate a key for ya, but you might go to a lot of trouble to only find out that the reason you don't have a key is that the system doesn't work. Or do you know the system works?
I know for my "84" that alarm lock is NLA...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 06-07-2009, 11:29 AM
Slumlord
Porsche_monkey's Avatar
You see a lot more posts looking for help to disable it than you do for how to enable it.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-07-2009, 02:33 PM
Transplanted User
mkossler's Avatar
Well, seeing as I have one, I'd also be interested in getting a key. The locksmith approach is probably best.
Matty K. - 82 SC Targa - SCWDP member #0052
"Racing - the sport that requires more than one ball to participate"
Old 06-07-2009, 03:08 PM
pmason's Avatar
What I did years ago was to buy a new lock assembly and it came with a new key.
Old 06-07-2009, 03:20 PM
Detached Member
Hugh R's Avatar
I don't think it comes apart. I read somewhere it's not just and on and off switch, it has different resistances that the system looks for in each position.
Hugh
Old 06-07-2009, 05:42 PM
Slumlord
Correct, from another thread:
Originally Posted by Early_S_Man View Post
... the specific resitor to use would be 4000 Ohms to 5500 Ohms between the cut door switch wires ... that specifies alarm unit OFF! A 2000 Ohm - 3000 Ohm resistor specifies alarm unit ON!!!
84 Cab - sold!
Old 06-08-2009, 05:42 AM
sent a pm for who has the blanks
Bruce
Old 06-08-2009, 06:56 AM
Jk369's Avatar
A1 Security Center
13 Coffman Ave.
Malvern, PA 19355
610-647-5042 fax 610-647-5950
http://www.a1securitycenter.com/
I handed the guy at the counter the whole lock and said I need a key, he replied for a Porsche right, no problem.
'80 SC 911
'67 Chevy SS Nova - Supercharged
'99 GSXR track only, '99 Superhawk
'05 Toy PU - daily driver
Old 06-08-2009, 09:26 AM
