Help, only 3 Qs for Weber masterbrains: I think these are easy.
I just got what I think is a 2.2 T standard motor and I just put on Weber carburetors. Everything about the engine is good, e.g. ignition, 4.5 psi fuel pressure. The carbs came off a different 2.4T engine. I have just tuned and synced the carbs and they are set up as follows.
2.4T 30 130 180 60 F26 I used an LM2 on all cylinders to get the idle circuits the same for all. They are all around 13.0 give or take .4 up to 3000 rpm. When I test for high speed with the LM2 on cylinders 1 and 4, I have A/F around 13 all the way up to around 3300 rpm and then it goes lean on me up way past 20-40 A/F with resultant popping and snapping, spitting etc. Obviously, I only tried this very briefly. According to experts, I should have the following: 2.2T 30 125 180 55 F26 Q1) Will changing the setup to the 2.2T setup help my lean condition e.g. change to 125 mains and 55 emulsion tubes? Doesn’t seem like that is the right answer. It seems like I need to get more fuel at higher RPMs or reduce the air intake. I don’t want to screw up the idle set up. It is fast and powerful right now up until 3300. Q2) Or should I actually increase the mains to get more fuel to reduce the lean condition? Q3) Or should I reduce the air correction jet fix the lean condition? Q4) Or should I do both 2 and 3. I do have 27 venturis on hand that I could try if that is an easy fix. Many thanks for your continued support. Marlin
Marlin Ness sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8 currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera |
I would rather be driving
If you have an AFR that high then you have more serious problems compared to slightly missized main circuit jets. It sounds like you have a plugged mainjet passage(s). The one-size change in jets will make a relatively minor change in AFR. If you are jumping from 13 to 20+ then you are just not getting any fuel.
I would solve that problem before moving on to fine tune the jets.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
At rest, you should be able to observe fuel discharging from each carb throat while reving the engine. If so, the main jet path is fine. A better simulation is when the engine is under a load (chassis dyno). If fuel discharges okay at 3000, but doesn't when it goes leaner at a higher rpm, suspect your fuel delivery system (pump volume, lines, filter).
Sherwood |
Now I have to think.
thanks guys. very good points.
what was interesting is that I had very good fuel delivery at 4.5 psi to the carb inlet. Nice full flow. So, I think it is with the carbs. Both 1 and 4 were almost identical on all the readings with the LM2 on each, and most of the others were also popping/snapping over 3k. So, I agree that this is something systemic and not one off. Unfortunately, I had to travel to NYC today and can't check again until the weekend. thanks again
the little venturis up top will plug in two ways. one way blocks the fuel delivery from the mains. the outlet tube, if you look down the hole in the venturi, needs to be on the side toward the emulsion tube/air corrector hole.
John,
thank you very much for responding. Do you mean the upside down big T looking thing that slides in over the venturi? I think most of the pictures shows this to the left of the float in the parts pictures. thanks in advance marlin
Sherwood |
Sherwood, John, et al,
thanks a million I will check them this weekend. regards marlin
