SWB vs LWB: Differences?
Hi everyone,
I've been reading through the forum slowly over the past few months, what a site! I thought it was about time I said hello and introduced my 'car'. I say 'car' because there isn't that much of it at the moment, the previous owner cut out 98% of the rot so the good news is what I have is quite solid, the bad news is there is a lot missing! It's a '66 SWB and started life as a 912 although I'm tempted to drop something like a 3.0 / 3.2 in it as I didn't get the engine with it anyway.
It's been sat in my garage over here in the UK for over 10 years and I feel the time has come to do something with it. I will get pics posted as I uncover the various parts from storage in the near future but one area I am a little uncertain of is what were the differences between SWB and LWB shells, apart from the obvious rear wing, swing arm and spring plate changes. I've read somewhere that the rear torsion bar tube may be different? I would really like to go LWB if possible (I already have later arms and spring plates etc), welding is one of my strong points (luckily!) so if it's possible then I think a '73 RS style is what I would go for.
Would appreciate any comments from all you guys that know a lot more that I do.
Regards
Neil
Old 06-15-2009, 09:27 AM
"farking Porsche hero"
Rich Lambert's Avatar
Neil, SWB hotrods are the new RS clones.
2 perfect examples
Converting a SWB to a LWB is a major undertaking, plus, the world would have one less SWB car. But then, I'm bias.
Good luck with whatever direction you go!
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 06-15-2009, 09:44 AM
Bye, Bye.
Scooter's Avatar
Why would anybody want a hotrod swb?
Elvis has left the building.
Old 06-15-2009, 10:32 AM
Band.
I love those No-Gruppe cars.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 06-15-2009, 10:37 AM
AutoBahned
RWebb's Avatar
cuz they like to spin out and twirl around
Old 06-15-2009, 11:05 AM
MarKoBrow's Avatar
A 912 SWB with a hot rod 4 cylinder (type 4 or 912) is the way to go in this car, The weight that is not present in the rear of these cars really makes them handle well. Combine this with lightweight and 200 Hp and you will have quite the car. SWB cars are getting harder to find and there are some of us would like to see the remaining ones stay short. It is however your car ......
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 06-15-2009, 11:25 AM
Zeke's Avatar
There aren't too many 200 HP 4 bangers around. By the time one wrung 200 reliable ponies from a 2 liter 4 (much less a 1600), he could have a variety of options for the same cost.
Aside from the obvious wheel base differences, the fenders are different. Less flare on the SWB if you want to even call the wheel arch "flared."
Old 06-15-2009, 11:43 AM
Thanks for the comments and the pics guys, keep them coming. The main reasons for looking at a LWB conversion are better handling (debatable?) and also I don't have any rear fenders of any description at the moment and I suspect later LWB ones will be easier to source than SWB ones. Plus I already have some LWB rear arms and spring plates so that's a couple of things less to buy. I think to be honest it's too far gone to put it back to original without spending a mountain of cash so I was looking for a slightly cheaper but ultimately just as rewarding option.
If anyone has a good idea of the torsion tube differences I would be interested to find out.
Regards
Neil Jackson
Old 06-16-2009, 10:01 AM
piscator's Avatar
Why and wherefore are there SWB and LWB P-cars? Sorry for my ignorance, but I'm new to the Porsche legacy. Is there something online that I can read about these variations?
piscator
Old 06-16-2009, 07:08 PM
AutoBahned
RWebb's Avatar
Frere's book - Porsche 911 will be your best source
The original 911 was the "SWB" type. Porsche KG (now an AG) did various things to try and fix some very bad handling traits. They put lead wts. in the front bumpers, they moved the battery around and split to a 2 battery system, they worked on adjustable upper shock (strut) mounts, and they lengthened the wheelbase, resulting in the monikers SWB and LWB.
Old 06-16-2009, 09:10 PM
MarKoBrow's Avatar
I prefer the handling of the SWB 911, with modern tires and shocks these cars make great track cars and are not to bad on the street.
2012 Audi A8L
Old 06-17-2009, 01:50 PM
304065's Avatar
Let's not forget that the demonic handling of the SWB 911 in the early years was associated with 165/15 Firestone Phoenix Tires. It's amazing what wider, modern compound tires can accomplish.
That said, "unsafe at any speed" was published around that time and the factory took advantage of the time-honored maxim of Torts that "evidence of subsequent remedial measures is not admissible to prove defects of design in products liability cases." Hence:
Cast-iron weights in the front bumper (1966)
Wider track (1968)
Front suspension that was actually adjustable (late 1965)
Revised alignment settings (1966)
Revised springplate bushings (1967)
Revised front crossmember and A-arms (1968)
Larger front antiroll bar (increased from 13mm pencil bar) (1967)
Fuchs wheels for less unsprung weight vs. steel wheels (1967)
Rear antiroll bar (196?)
Finally they gave up in 1969 and ended up with:
Flared fenders for wider tires (185/15)
Longer wheelbase
Dual batteries way up front and outboard (there is NO electrical reason for this, it's a weight thing)
Revised front suspension design (different balljoints and crossmember)
That didn't solve it, in 1974 they went to enormous aluminum bumpers and a single battery
1989 coil spring suspension and radically different suspension design
1995 even more radically different suspension design
1999 end of original 901 design. New 996 design debuts with engine in same location!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-17-2009, 02:29 PM
Max Sluiter
Flieger's Avatar
...and a yet longer wheelbase
Old 06-17-2009, 02:51 PM
AutoBahned
RWebb's Avatar
very thorough John
you left out sPASM for the most recent cars is all...
Old 06-17-2009, 03:07 PM
boxster03's Avatar
So how many SWB vs LWB races were won What was the score -- that will tell the real difference
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 06-17-2009, 05:56 PM
AutoBahned
RWebb's Avatar
not really - the competition changed too
Old 06-17-2009, 07:04 PM
boxster03's Avatar
Exactly. Porsche changed/competition changed. How did the SWB vs LWB fare against the competition.
1970 911E
Yadda Yadda Yadda
Old 06-18-2009, 07:00 AM
Hi Neil
I just changed my car to LWB. After asking many people about the differences here is my findings. There are people out there that installs lwb trailing arms into swb cars and they say it works fine. (the one is a reeputable porsche specialist). I say Bull S
The SWB mount on the torsion bar sit in the center of the hole for the trailing arm where the LWB sits futher back and off to the side. In my opinion you will struggle to get the wheels to run straight if you place LWB arm in SWB mounts. You are working with a triangle and not doing it right you are getting the angle out.
What I did is bought a piece out of a rust bucket, cut of the LWB mounts made a jig from another LWB car and then welded in my LWB mounts. I include a pic of where the mouns sit on LWB SWB and Carrera
68 S Targa
68 ST Replica
69 S Coupe
59 VW Samba
65 E Type S1
Old 06-18-2009, 10:28 AM
leonpotgieter,
Thanks so much for the info and the pic, that is exactly what I needed to know. Nothing too difficult then, I just need to source a scrap LWB donor car and cut off the mounts to graft them on to mine. Another thing to add to my shopping list!
Thanks again
Regards
Neil
Old 06-18-2009, 10:45 AM
MarKoBrow's Avatar
Originally Posted by leonpotgieter View Post
Hi Neil
I realize this is an old thread, I am trying to understand your explanation. If you were going to remove the SWB mounts and move them to the correct location where would that be? I ask because I am in the middle of a conversion on a car that has no torsion tube at all right now. the plan was originally to do an a-arm rear suspension but thanks to two fellow Pelicanites I received some Long wheelbase swing. these with some 935 coilovers could be combined to jump-start my rear suspension. I just need to where the rear arm mounts are in relation to the existing mounts.
2012 Audi A8L
Old 06-04-2010, 08:49 AM
