Ski it like a man
CB911's Avatar
Help with a lazy visor
The drivers side visor in my Targa drops slightly in cold weather. Once the weather is warm and sunny, the visor will stay up. I live in a colder climate, so the visor is usually dropped, very annoying. Just wondering if there is a better fix than using velcro.
Thanks.
'83 SC Targa
Old 06-17-2009, 12:37 PM
1968 2.0s
My visor has a small screw where it attaches to the arm, it adjusts the friction... half a turn too tight and it locks solid, half a turn too loose and the visor is too floppy. I carry a screwdriver in the glove box.
Hope this helps, Mike
1968 Super. 1959 Super.
http://tinyurl.com/pbvfl5w
Will this learning curve ever level out ?
Old 06-17-2009, 01:13 PM
Wash. State
nesslar's Avatar
Mine on the passenger side needs to be tightened at times (I went to larger "same style" black screws in both visor mounting brackets and the passenger side STILL will get loose) but this sounds like a diff problem, as noted in post 2..... ? Lar ....screwdriver also at hand.....
Old 06-17-2009, 01:49 PM
