Good Ole Boy
dalematt's Avatar
Help Identify this engine
I know, there's a million threads on engine ID numbers, but this one doesn't seem to be in the book, or the type and number don't match up anyway. The engine is a type 930/04 and the ID number is 6462118. To me that reads a 1976 engine but Wayne's 911 engine book doesn't list a 930/04 until 1978....
So what do I have? Any help or insight greatly appreciated...
I can say this; it has non Lamba CIS and the casting number by the oil return tubes starts with 930 (don't remember the rest) The engine is currently in a 1981 SC coupe but it's definitely not original to the car. The PO said it was a used '78 3.0 installed sometime in the past by a previous PO. But that doesn't add up with the ID number.
1977 911S 2.7 Sunroof Coupe (My Midyear Crisis)
1998 Honda Shadow ACE 1100
1990 "Redneck Porsche" 5spd, 7.5 litre efi 4x4 Regular Cab F-250
Old 06-18-2009, 07:19 PM
49 state, '76 911S.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 06-18-2009, 07:58 PM
Well, you need to have a star on each end of the ID number so it might be a recase.
Bruce
Old 06-18-2009, 08:06 PM
Good Ole Boy
dalematt's Avatar
that would be true, if it were a type 911/82..... right? this is a 930/04
Old 06-18-2009, 08:07 PM
feelyx's Avatar
Its a 3L just by the dist. size. but, I don't have my book handy.
Tim
98 Boxster
87 560sl
04 S2000
Old 06-18-2009, 08:24 PM
feelyx's Avatar
Punch one of the CIS runners part #s in the seach engine that will atleast tell you if the CIS is from a 78. Dia. of the fan will give some indication also.
EDIT: 78SC by the numbers
Tim
98 Boxster
87 560sl
04 S2000
Old 06-18-2009, 08:36 PM
Author of "101 Projects"
Wayne 962's Avatar
I have a very rare chassis / engine number book from Porsche, and that is what I based my engine number section on. I'm pretty sure it's very, very accurate. That said, there are variations that people have found, and I believe that they probably correspond to replacement engine cases. In this case, I would guess that this was a replacement engine case too.
-Wayne
Old 06-18-2009, 09:01 PM
Good Ole Boy
dalematt's Avatar
I tried that with the numbers on #4 runner, got nothing.... I know it's an aluminum 3.0 liter, was just curious what's in it and what it's out of.....
The numbers on #4 runner are 911 110 189 48 (guessing the last two numbers, they're hard to read)
The fan is smaller than the one on my '77 2.7. I measured the inside of the housing with a brake drum caliper and got about 8 3/4" (sorry for not doing metric, it's late). The number on top of the fan housing is 930 106 101 0R
Old 06-18-2009, 09:13 PM
feelyx's Avatar
911.110.169.41 is from a '78 (larger) runner, and by the fan being smaller, a 226 and not the 245 is in the 78/79 year range and with the 930/04, I would say '78 is the year. But you never know with the hodge/podge that gets put together sometimes.
Tim
98 Boxster
87 560sl
04 S2000
Old 06-18-2009, 09:30 PM
Good Ole Boy
dalematt's Avatar
Thanks Tim, that's pretty much all I wanted to know.
Dale
Old 06-18-2009, 09:46 PM
