setting mixture, jumper which ports to make car ignore o2 sensor?
Hi guys,
I am setting my mixture on my carrera, and instead of unplugging the o2 sensor, i was wondering which test ports under the rain guard on the left side of the engine bay i could jump with a paper clip to have the motronic system ignore o2 sensor input?
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 06-23-2009, 08:04 PM
Industrial Grade Tool
WoodSport's Avatar
1 o'clock and 6 o'clock are the positions to jumper in order to remove the idle control valve from operation when adjusting the mixture. Is that what you're looking for?
/Jon
Old 06-23-2009, 09:09 PM
No, not that one, i'll do the idle speed adjustment after. The one i need is to ignore the o2 sensor input as if it is disconnected. I read somewhere on here that it was possible but didn't read which ports to jump.
Old 06-24-2009, 06:31 AM
abit off center
cgarr's Avatar
Near the bottom of this PDF file it shows the jumpers to use on the plug in the engine compartment: I understand this bypasses the O2 sensor from what Steve told me, maybe not? From SW site:
http://www.911chips.com/C1INSTR.pdf
______________________
Craig
G2Performance
Old 06-24-2009, 07:00 AM
Those instructions are also for the idle speed.
Old 06-24-2009, 11:23 AM
Isn't it just as easy to unplug the connector?
Old 06-24-2009, 11:55 AM
Its a bosch universal connector with 3 seperate posilock connectors, with pressure weather proof plugs to keep water out but let air in, its supposedly a proper replacement for the crumbling stock motronic connector. It would be easier to just jump 2 socket terminals. FML.
Old 06-25-2009, 08:03 AM
