LinkBack Thread Tools Rating: Thread Rating: 7 votes, 3.86 average.
gulkster's Avatar
DIY leak down/compression tests
I'm a total DIYer (as many here are of course). I want to check the condition of my 3.0l, and would like to do these (leak down if necessary after compression). I have a home made leak down tester (haven't used yet) made from welding a male hose end to an old spark plug (saw it on speed channel). I guess I could use it a compression test too, as long as I have a gauge that plugs in? Any suggestions on what I should buy/make so I can do this myself, AND do a good job would be greatly appreciated. TIA.
Jamie
edit: did a search and didn't come up with anything about DIY stuff I am looking for
T-Shirt wearing, sticker toting, SCWDP registered member
Why when you misplace something is it always found the last place you look? Because you stop looking after you've found it
'83 911sc ROW Targa
'84 BMW 320i (what did I get myself into?!)
Old 06-29-2009, 09:42 AM
docrodg's Avatar
It should already have a gauge on it (about 150psi) if it is for doing a leakdown test, just have to get one that it is high enough reading to add for doing compression. Grainger can be a good source for pressure gauges - get one that reads about 300-400 or so to make sure you do not overpressure it when running compression. Also add a one-way valve just behind the fitting so the pressure stays in the gauge. The leakdown tester you made should have a shutoff on it to stop flow of air, just turn off the valve and hook up the tester with the higher reading gauge, viola! compression tester. When done with a cylinder open the valve to bleed off the air.
Leakdown testing is far more informative of problems than compression testing.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 06-29-2009, 04:43 PM
Send a message via AIM to morrisjm1 Send a message via Yahoo to morrisjm1
Check this out, I don't think you could build one for a whole lot less than $60.00 and this is a real one.
Mike
http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=2E-14&ReturnPage=/shop/search_result.aspx?PageNo=5
'78 911SC Targa (SCWDP member #17)
'74 MGB (one owner)
Pickup
2013 Ford Explorer Sport
2013 VW Golf TDI
Old 06-29-2009, 05:04 PM
Platinum Member
dad911's Avatar
Leakdown tester is 2 pressure gauges with an orifice in between, and a regulator. Extensive thread here:leak down test
Old 06-29-2009, 05:29 PM
Less brakes, more gas!
euro911sc's Avatar
I bought my longacre leak down unit off ebay for like $50 shipped... not worth the time to make your own... IMHO and I'm a serious DIYer like your self.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-29-2009, 07:02 PM
T77911S's Avatar
Mike
i dont think that one will work. the part that screws into the Splug hole is too short. most have a longer hose attached that allows you to screw it in. looks like a good deal otherwise.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-30-2009, 05:58 AM
gulkster's Avatar
Thanks for all the input. It looks like ti is worth it to just get one of those "pre-made" ones I will definitely need one with a long hose. I started to do a compression test last night to see if a leak down was needed, and only managed to get two cylinders done before it dark It took forever to try and thread the gauge into the head, it has to be 3.5-4 inches down there...and at an angle. Cylinder 4 was 125psi after 4 bumps, 140psi max (after 6 bumps). Cylinder 5 was also 125psi after 4, and was 145psi max after 6. So far so good. I will do #6 tonight as I only have a bit of time. I love this car b/c working on it is a bit of a conundrum: manuals say to do the compression test when the engine is at normal operating temp, but it also says don't remove the spark plugs until it has cooled down!
'83 911sc ROW Targa
Old 06-30-2009, 09:14 AM
gulkster's Avatar
dbl post
'83 911sc ROW Targa
Old 06-30-2009, 09:16 AM
Home of the Whopper
Personally I don't even bother with compression tests anymore. A leakdown is easier and better. I haven't noticed much difference in cold / hot engine either, and would much rather work on a cold engine. Plus a leakdown can be done with the engine out of the car. Ok, rant off.
Here is a leakdown tester I made for about $15. All you need is a regulator, pressure gauge, old spark plug and some tubing. Wham bam.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 06-30-2009, 10:05 AM
Platinum Member
dad911's Avatar
BK, how do you do it with 1 gauge? and no orifice? Pls see my other post.
Old 06-30-2009, 10:11 AM
Home of the Whopper
I didn't have time to read the entire other post, but basically...
The compressor regulator is set at about 75psi.
The leakdown regulator is set at 50psi.
Screw the hose fitting into the plug hole.
Attach the other end of the hose to the regulator.
Subtract the new pressure reading at the leakdown regulator from 50psi then double.
For example, when the fitting is plugged into the 50psi regulator, the pressure immediately drops to 45psi. That's a 10% leakdown.
That's the way I do it. Please tell me if this is wrong!
Old 06-30-2009, 11:27 AM
T77911S's Avatar
i usually do it cold. trying to be fast enough to do it hot is tough. do you make corrections to the first one done and the last one done to allow for temp change?
i dont put much value in a leak down as far as a % number. it is a great tooll to locate the source of low compression, but i would always do a comp test first, if the conditions allowed. i bought my LD because i bought a used 3.0 and i wanted to try to test the motor before i tore it down.
maybe i just dont understand the procedure, but when i was trying a LD yesterday on my truck, i could set the regulator so the % was always 0 or 80 or 70%. BTW, my truck was 145 psi for all 4.
i would think for the LD to be acurate, the incoming air pressure would have to be set for max reading on the piston side gage while connected to something that has no leaks like a plug or a plug with a .040 hole in it like the one between the 2 gages. in other words, some way to calibrate it for a known % of leakage. i may get it back out this afternoon and mess with it some more.
my harbour freight gages reads 15psi when the other gage shows 0% LD. the left gage goes to 100psi, i geuss the right one only goes to 15psi?
RACE CAR:: sold
Old 06-30-2009, 11:36 AM
gulkster's Avatar
Unless I completely misunderstand how the damper (0.040 hole) works, which is entirely possible, the above method makes sense. I don't understand why you would need to double the (edit) difference number though. Can someone straighten me out please.
'83 911sc ROW Targa
Old 06-30-2009, 11:57 AM
Platinum Member
dad911's Avatar
BK - I get it.
gulkster - BK doubles the scale, because he is using 50psi, not 100 psi, and you want 100% full scale. Multiplying x2 is short-cut, same as taking the percentage, 45/50 x 100.
Old 06-30-2009, 12:05 PM
gulkster's Avatar
Hahaha...I was so focused on the physics, I TOTALLY missed that That is the funniest thing...
And thank you.
'83 911sc ROW Targa
Old 06-30-2009, 12:12 PM
Mike
"i dont think that one will work. the part that screws into the Splug hole is too short. most have a longer hose attached that allows you to screw it in. looks like a good deal otherwise."
Seems like a simple matter to insert a short length of NPT-nipple to lengthen the spark plug adapter. Of course, there may be other brands with a longer hose attached to the adapter. Snap-On has one (see below), but not for $60.
Sorry about the giant size.
Sherwood
Old 06-30-2009, 12:50 PM
Jim Williams's Avatar
FWIW, here is the leakdown tester I built several years back from parts lying around in the garage. I did have to buy a second 100 PSI gauge. I installed a smallish restriction between gauge 1 and gauge 2 (don't recall the size). I borrowed a commercial tester, I think a Tavia, to compare readings with. To make a long story short, there was a significant difference in the readings, which I attributed to the orifice size, so I measured the one in the Tavia, and made mine like it. It's been too long back, and I don't remember the actual orifice size I ended up with.
I had searched every source I could find and like others have found, there does not appear to be a standard orifice size.
I have never found the hose supplied with most leakdown testers to be satisfactory for use on the 911 engine. They don't result in a consistent seal, and sometimes when tightened, the connector on the the sparkplug end will twist on the hose, leaving a problem to get the hose out of the head. I made up a a solid connector with an air hose fitting on one end and a spark plug fitting on the other. A deep well socket is used to tighten this connector in the spark plug hole, and the right angle connector on the leakdown assembly makes an easy hookup to connect the gauges.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 06-30-2009, 06:03 PM
dshepp806's Avatar
i've always been told (?) to do both compression and leakdowns, as they lend different data.
True?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-30-2009, 06:39 PM
T77911S's Avatar
now i see how that works. i need to look at mine again. yours has the female chuck on the regulator, i cant remember if the female chuck on mine is on the hose that screws into the head. if the male part is on the block with the 2 gages and the reg., i cant set the air pressure before i connect it to the hose that goes to the head. duh,
if you connect the regulator to something with a .040 orifice in it, then set the reg to 50 psi, removed the .040 orifice and then connected it to the hose to the head, would that give you a more acurate reading?
RACE CAR:: sold
Old 07-01-2009, 06:11 AM
gulkster's Avatar
I realize this is a bit off topic from my original post, but its still within sight Can anyone give me some tips/explanation on how to get the socket on to the #1 spark plug? For some reason I cannot get the socket on. The other five are fine, so I'm not really sure what is going on down that hole. It feels like the socket just can't grab the plug. Do I need a really thin walled one due to the odd angle maybe?
TIA.
Jamie
'83 911sc ROW Targa
Old 07-01-2009, 08:51 AM
