scotricker's Avatar
Can I fix this Clock?
I looked in the tech articles section, and found articles on 914 clock, but how about this one?
Can I open it up? Is it those three screws on the back?
Then what happens inside there? Clean it , or check solder joints, etc..
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 07-04-2009, 04:07 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, three screws but also that copper flange needs to be de-soldered to release the back from the face.
But prior to doing that check for a short from a broken solder.
Take a Digital Volt Meter in "Short" mode if there is a short you will know where to start. If there is no short it might be a broken or loose sprocket.
Hope this helps,
Jim
'85 Carrera Targa
PCA/POC
Old 07-04-2009, 04:24 PM
scotricker's Avatar
volt meter checks ok.
so the clock grounds to the case by that solder?
I'll un-solder the copper disc, and take off the screws and see whats in there
Scot
Old 07-04-2009, 04:35 PM
DRACO A5OG's Avatar
Yes, the internals ground via that disc and finally thru the housing's ground terminal.
'85 Carrera Targa
PCA/POC
Old 07-04-2009, 04:47 PM
scotricker's Avatar
screws out, disc un-soldered loose, clock is loose inside there, but now how do i get the front glass/bezel off to get it out?
Scot
Old 07-04-2009, 04:53 PM
scotricker's Avatar
ok, got it all apart. An article I found explained to bend the edges of the front bezel to remove guts. It all looks squeaky clean and fine in there, no obviously broken anything.
I guess its time to look in the used parts for sale forum.
Scot
Old 07-04-2009, 05:44 PM
muck-raker
kidrock's Avatar
some people are deleting their clocks, and either covering up the hole...or fitting a more useful electronic unit in place of the clock. My clock works, but I'd like to put in one of those digital AFM gauges.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-04-2009, 05:53 PM
