Pure Awesomeness
szyzygy's Avatar
Question Right Turn Blinker on Dash Stopped Working
I noticed I was driving around a bit today with my right turn signal on after switching lanes, and it didn't self shut-off. That's not like me. Then I noticed it was because the flashing light wasn't there to remind me.
The exterior turn signals all work, and the left blinker on the dash works.
Hazards all work, too, but they don't cause the dash blinkers to flash. Seems like most other cars I've owned, the hazards affect the interior flashers as well.
So what do you guys think is the issue? Bulb? Loose wire? There wouldn't be a separate relay for each blinker light, would there?
TIA
1977 Porsche 911
Old 05-21-2012, 05:57 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Pull the gauge and check the bulb, swap to check it is not the socket or wiring. Probably jusy the bulb. don't sweat it.
Dosconnect the battery when you do, just incase the hot lead hit the chassis. Also best to pull the clock then speedo, reach in behind it and push the Tach out.
'85 Carrera Targa
PCA/POC
Old 05-21-2012, 06:42 PM
Dublinoh's Avatar
Tack is the tough one, need to remove steering wheel and clam shell.
Old 05-21-2012, 07:02 PM
Pure Awesomeness
szyzygy's Avatar
Thanks guys. I'll check the bulb. if theres one thing I'm good at, it's removing the wheel!
Wish I knew the bulb was bad earlier yesterday....just ordered a bunch of stuff from our sponsor.
1977 Porsche 911
Old 05-22-2012, 06:09 AM
RETIRED
Joe Bob's Avatar
I've pulled the speedo, reached in and got the bulb in question out....lot easier.
2012 ML350 3.0 Turbo Diesel
Old 05-22-2012, 07:02 AM
Porsche dreamer.....
Send a message via AIM to vwporschegt3 Send a message via Yahoo to vwporschegt3 Send a message via Skype™ to vwporschegt3
did you check your blinker fluid? sorry couldn't help it
remember always leave your foot on the GAS through a corner.....
Old 05-22-2012, 09:53 AM
Pure Awesomeness
szyzygy's Avatar
I pulled out the tach to the right and reach in around the back of the speedo. I felt a hole where the plastic cap should rest. Closer inspection revealed that the plastic housing & bulb had simply fallen out behind. I put the key in the ignition, and used my turn signal. There is was, flashing away. I plugged it back in and back to normal.
Thanks everyone. Glad I didn't even have to take the wheel off using the ole' tach trick!
1977 Porsche 911
Old 06-04-2012, 06:00 PM
