dry ice is our friend
After reading a few posts about dry ice on door dings, I decided togo ahead and try it. I finally figured out where to buy it here. I had heard about this before, but was reluctant to put it on my paint. The recent posts here about it gave me enough confidence to try it. I am sorry, but no pics tonight. I will try to get some tomorrow.
I used it on some typical door dings. The results were not 100% perfect, but definitely made a big difference. I am probably being too timid about how long I am keeping it in place, and will reread the threads here on the list later tonight to make sure I am getting the full effect possible. I see no damage to paint at all, of course, I will probably wake up and wonder where the golf ball chips of paint came from! I will try to post pics and more details tomorrow...
Shane - 1984 928S |
AutoBahned
is this on the exterior of the door?
or did you remove the panel and reach into the door well to the cabin side of the panel? |
Re: dry ice is our friend
http://www.metacafe.com/w/494805
Euro 1989 Carrera 3.2 Paint Code L 693 Stone Grey 45,000 kms logged |
Re: Re: dry ice is our friend
Randy, for what I did yesterfay, I was on the outside only...
Shane - 1984 928S |
Gon fix it with me hammer
i did the same on my door
not perfect yet, 't was a combined dent over a larger area and my freezer spray can ran out to early but it definately works my biggest problem was the nozzle, it came without and it's painful to the fingertips if you freeze those instead of your dent...
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
what happens when the dented area goes into the sun? Will the area go back to the dented state?
I live for 911 tweaks... |
nope
the metal wants to be in an undented form it was pressed that way, and the dent is not how it wants to be by heating it with a hair dryer, and then quickly cooling it you first soften the metal, and then put tension on it by cooling it ultra fast... this makes it overcome the dent and return to it's original state... and it will stay like that till you dent it again...
Information Junky
"soften the metal" !?
I think it has more to do with thermal expansion rates and internal stresses.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
yeah , that
all i know, is that it works, and it's permanent
sudo apt-get purge 930
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Although I know the method works, I was not able to get it to work on my 924S using dry ice.
We used to do this to suits of armour when they got dented during sparring/battle in the SCA. But, it involved a torch and ice-water, not a hair dryer and dry ice.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Registered Loser
I started one of those threads about dent repair but my results were nil. If anyone can give advice on how to remove dents with heat/cold successfully, I am open to any suggestions.
Owner of a wrecked 944 |
One technique of the dent puller trade is to glue on a small stud then lightly pull it with a slide hammer. The glue is then removed with a chemical. If you pull it out too far, you simply tap it back down. I have watched a guy do hundreds of dents (hail) on a body panel without 'pushing' out the dents from the back side which is the standard method.
Be careful removing dents on resprayed panels where the adhesion may not be as good as the factory paint.
Randy '87 911 Targa '17 Macan GTS |
the ice method i used, also from a video, is not with dry ice
it's with an inverted spray can so you can spray in a very direct and localised area seems a lot more effective then the dry ice video
Does the Carbon Dioxide method damage the paint. I notice the paint surface on the video is kindda dull.
Fat butt 911, 1987 |
didn't notice anything on mine...
i think it just looks duller then the panel to the right because it's angled differently in the light
svandamme,
Thanks for responding. On the short movie, the dent seem to be big dent without sharp edges? The kind of dent yuo an pop it out by hand from the inside. Have you ever tried this method on the smaller ding? Also, where do you by the carbon Dioxide spray can? Thanks.
my dent had more obvious edges, although still not "sharp"
it still popped out i used an air can intended for one of those air horn's just compressed air, but when inverted, you blow the propellant first, and that freezes mind you, the can is empty reaaaal fat when you do this... i need to get myself another one to finish my dent removal i don't think it will work on dents that are to small
I wonder if I can do the same as you do using those "keyboard duster" spray can...
