Would you use this tool?
Hey guys, would you use this 12 point tool to remove those risky flywheel bolts or order new through Pelican?
Boy, I hate to strip those buggers! Is there a difference in quality between them? Purchased a set of four for $13.00 at local auto parts store. Regularly $24.00. ![]() Thanks, Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car Last edited by LeakProof; 07-07-2009 at 06:13 PM.. |
They all go bad after a time. You can grind the face to give you new surface. Even Snap On goes bad after a time. Like stud removers, they are consumable tools.
Bruce |
Thanks, flat6pac for your response. I'm still trying to contemplate if the one from our host would be for any reason a better less risky choice?
I guess I could find the answere out in about five minute or so. Just trying to prevent learning the hard way. Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car Last edited by LeakProof; 07-07-2009 at 06:45 PM.. |
While guys, I'm not going to sweat this one to much.
For $19.99 through our host I'll just order theirs. Perhaps it's a better fit. Why risk it. Thanks, Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car |
Schleprock
I have used the local store-bought Lisle brand triple square/twelve point bits on my flywheel bolts and some CV joint bolts for a number of years and they're still serving me well. I'm not a pro-wrench, just an avid DIY guy.
I'm all for supporting Pelican because this place is invaluable. But when it comes to tools, get 'em local if you can and save yourself the hassle of waiting for something to ship. It's very frustrating for me to wait for tools and delay getting something done!
Kevin L '86 Carrera "Larry" |
Less brakes, more gas!
I got mine at the FLAPS. Used it... lent it out... used it again... no damage or anything *shrug* I actually bought a kit with multiple sizes. Never know!
best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
abit off center
A dab of lapping compound on the tool helps it hold a better bite too!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Nothing wrong with that tool, your way over thinking this just use a deep socket to keep it from moving.
68 911L |
Hello,
It's been a while since I've messed with flywheel removal, but I'm thinking that on some of the models they are stretch bolts, so messing them up it bit, as long as you get them out might not matter, since you have to replace them anyways. Does anyone else know for sure? Rutager |
My lisle triple square has pulled off hundreds of flywheel bolts without issue. I did break one in half a while back (tool that is), but I have never stripped a bolt with one. I use an impact to remove them and I cut some length off of the tool to make it a little less cumbersome while toruquing them up.
No left turn un stoned |
yup id be more worried about snapping off the tool than stripping the bolts
82 SC , 72 914 |
Super Moderator
An impact really helps with these types of bolts... I've used mine on probably 100 of them with no issues.
While guys, heres the tool within the first 2 seconds of attempting this feat.
![]() Bolt didn't even budge. Doesn't look like any damage to the fastener. although they look a little worn. maybe from original install? Looks like the tool failed instantly. Needless to say I just ordered the 12 point socket tool from our host. Yea, cgarr what exactly is lapping compound? sounds like a good idea. Perhaps I should use a impact drill? Also what happens if a bolt breaks in that $4500.00 crank? Whats the worse case scenario if I strip a fastner? Maybe I should leave this to the pros? I think I'm starting to stress. Thanks, Leakproof
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car Last edited by LeakProof; 07-08-2009 at 05:01 PM.. |
abit off center
The lapping compound, like valve lapping compound is a grit that helps the tool from slipping, used a lot with tight Phillips head screws and alike. Looks like your tool was not a good quality to do the job, it should not do that, good that you got a good one coming, otherwise its the same tool used on many head bolts on engines now a days. I dont know if your bolts had any loctite on them but if they did a quick shot of heat will loosen it too.
9 bolt cranks only torque to 66 ftlb. an impact gets them off easily, as well as a breaker bar. the tough ones are the 6 bolt craks that torque to around 115 ftlb. the trick with those is to take a heavy ball peen hammer or mallet and give them each a sharp wack square on top of each bolt before attempting to loosen them. then use the breaker bar.
Make My Day
Hmmm, I used the cheap auto store ones and they worked great.
Better hope the $19 set works or could turn out to be a real PITA.
74 911S Targa ROW Building Designer/Business Owner |
Strip the head and you will be making one of these.
Look closely and you will see the flywheel bolt on the end (from 6 bolt crank). Sometimes desperate times call for desperate measures. +1 for the solid whack on the bolts first. Good luck Leakproof.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
I've always and inevitably found that you can buy cheap tools a number of times or the right tool once.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
First off, I really want to thank you guys for all your excellent advice/knowledge.
This site is unbelievable! Cgarr, thanks for getting back to me on the lapping compound. J.w. workshop, you made me feel much better about the situation, luckily I have 9 bolts. I sure hope this does not become a PITA Wowzer911. 9elf, I won't even ask, at least not yet. Now that I'm done with all my thank yous I sure hope this all works out when I attempt it for the second time. Perhaps it will be a piece of cake. Will definitely let you know how this pans out. Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car Last edited by LeakProof; 07-08-2009 at 07:22 PM.. |
Detached Member
I've used cheap Chinese tools a few times and ended up spending too much time fixing the damage. Use good tools
Hugh |
