sigep174's Avatar
'80 911SC low idle/stall at running temp
I recently acquired an '80 911SC Euro. The car seems to be spot on, but has started stalling after the car has reached normal running temp. I have adjusted the idle up a few times thinking that it was simply a loose idle screw, but it seems to be something else.
Thanks,
John
Old 07-17-2009, 09:16 AM
sigep174's Avatar
Is there anything I should add to this to help facilitate some speculation?
John R James, Jr
'80 911 SC Targa (Euro)
Old 07-18-2009, 12:06 PM
Where is that wrench?
EdT82SC's Avatar
May be a vacuum leak. Does your idle drop when you remove the oil filler cap?
Ed T.
1982 911SC
Porsche Wallpaper
Old 07-18-2009, 12:11 PM
sounds like a vac leak messing up the mixture. depending on where it is, the warm-up sequence may mask it.
Another other option is your CDI box is getting flaky - as the temp goes up, the spark energy falls. This should be a problem across the rev range, not just at idle.
Don't Lift... Don't Lift... Don't Lift
'75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade.
Old 07-18-2009, 02:12 PM
Idle issue
I have an '83. When I replaced the thermal switch in the right hand cam cover, my idle became a lot more stable.
It is a thermal/mechanical switch that sends a signal to the computer that the car is warm and needs another mixture profile.
Might be the same on an '80 Euro.
ST
Old 07-18-2009, 03:29 PM
JoeyD911's Avatar
Not to hijack, but is that the cam temp sensor, TT?
Joe D
L.I. NY
82 911 SC 3.0
Swartzmetalic
Old 07-18-2009, 07:09 PM
sigep174's Avatar
I will give that a try this evening.
John R James, Jr
Old 07-20-2009, 01:19 PM
EdT82SC's Avatar
I should have explained a bit more. Removing the oil filler cap simulates a vacuum leak by letting air into the system. If you already have a vacuum leak removing the oil filler cap will have no effect. So normally your idle will drop when you remove the cap. Finding the leak can be a fit more difficult though. Rubber vacuum lines and seals dry out and crack with age. With a nearly 30 year car there are probably multiple leaks.
Ed T.
1982 911SC
Porsche Wallpaper
Old 07-20-2009, 01:49 PM
Designer King
Paulporsche's Avatar
Check your warm control pressures (WUR).
Also, what type of CDI do you have? There are many reports of certain Permatunes having problems when they get hot.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-20-2009, 07:26 PM
