LWJ LWJ is online now
Killer Tip - motor mounts
Score one for Charles K who posted a tip on motor mounts. I did these tonight and it was an absolute breeze.
Here is the tip:
1) Super glue the lock washers to the nuts.
2) Put duct tape sticky side out on your middle fingertip.
3) Place the nut/washer on the tape.
4) Tighten the bolt with the nut in place on your finger.
Let me tell you there is genius in this!!!
I have used masking tape to hold the nut & washer together in the past. This is 100% better than that.
In my clumsiness, I did invent a tool that has considerable merit. My daughter seems to have run off with the magnetic picker upper with the long flexible handle. I dropped a nut/washer and needed an easy way to pick it up. I found a rare earth super magnet and taped it to a small dowel. PERFECT. Even though the magnet is less than 1/2 inch in diameter, it had the power to pick up on of the large washers that goes under the motor mount.
Just thought I would share.
Larry
Old 07-18-2009, 11:35 PM
Band.
You must be one of THOSE guys who has an OLD car whose motor mounts actually need NUTS
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 07-18-2009, 11:50 PM
Neodymium magnets are awesome. 1/2 inch is huge for a Neo magnet.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 07-19-2009, 12:23 AM
safe's Avatar
Never realized it was a problem...
Magnus
Old 07-19-2009, 12:16 PM
