byfdinky's Avatar
Dashboard Heater Conrol Panel
Planning to replace the 4 lights behind the control panel due to their excess heat that has disfigured the 4 mounting holes
I would like to replace them with a new wiring harness with (4) 12 volt clear LED assemblies.
I checked with Radio Shack and found colored 12 volt LED assemblies but no Clear
Does anyone have a source for the 12 volt Clear LED assemblies?
Many Thanks,
Bill
1979 Targa
Old 07-21-2009, 06:37 PM
steely's Avatar
Just LED's? - maybe Digikey?
Not sure I follow the application, but I saw some thread regarding illuminated tape or in dash LEDs where they recommended 4 leds per original lamp (as in 16) in the case of clear color.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-21-2009, 08:01 PM
JTL JTL is offline
JTL's Avatar
Arrow
The 'mounting holes' are a part of the panel so you pretty much have to replace the whole panel to fix it. Maybe there is a way to rig something aftermarket, I dunno?
I just replace the panel in my -84. The job wasn't all that bad. Lucked out and found a good used panel in the parts FS section...
jt
Old 07-21-2009, 08:04 PM
Member 911 Anonymous
DRACO A5OG's Avatar
try www.superbrightleds.com
You will want 74 = 2721 wedge type mini bulbs
'85 Carrera Targa
PCA/POC
Old 07-21-2009, 08:12 PM
muck-raker
kidrock's Avatar
Dude, are you stripping your Targa bar, or was it already stripped?
Whatever you're doing, keep it up...it looks saweeet.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-21-2009, 08:27 PM
